Thread: How "built" is my transmission?
Results 1 to 13 of 13
  1. #1 How "built" is my transmission?
    Sep 2019
    Brownsburg
    2002 40th GTP that I bought has had a lot of work down to it. A couple owners back and they had all of it done by shops. Have a lot of the receipts still. one is for transmission work done 10,000 miles ago. The car had 293 horsepower and 355 ft lbs torque last time it was tuned which actually seems low for all the performance parts it has but I'm gonna make another thread for that. My concern is is the transmission built to handle the power the car is putting out. Upgrades and repairs listed when the transmission was serviced are
    EPC Solenoid, Shift Solenoid, Various?? Solenoid, Filter, Sprockets, Master Overhaul Kit, 4th Gear Hub and Shaft, Shift Kit (Must be light cuz I dont feel it much), Drive Chain Set, Channel Plate Sleeve, Reman COnverter, Input Sencor, Billet 3rd GEar Piston, 300M Input shaft.
    Obviously other stuff could have been installed prior or after this but this is all I know for sure. Thanks for your thoughts guys
  2. #2 Re: How "built" is my transmission?
    they say stock tranny is good for 350 hp. the stock input shafts like to snap tho, so that 300 mm input shaft is a win.
    what mods the engine got? if its got a cam it should be around 330 or so. trans tune makes the tranny feel a lot better too. no idea on its tuning work if any.
  3. #3 Re: How "built" is my transmission?
    Antioch, IL
    300m good, billet 3rd good its what I ran on the turbo. Tune it if you want more shift bite, other than that, rock it out it will hold any m90 power.
    2009 Challenger SRT8
    Expert at being gay.
  4. #4 Re: How "built" is my transmission?
    Sep 2019
    Brownsburg
    It's got a ton of mods. Well a ton in my opinion
    -3.3" Pulley
    -Headers
    -3" Downpipe
    -3" ZZP Exhaust and Mufflers
    -Fenderwell Cold air Intake
    -Northstar TB
    -GenV SC (Possibly Ported)
    -Ported Stage 2/3 Heads
    -Roller Rockers & Lifters
    -125# Lifters
    -XPZ Cam
    -L32 Bottom End (Balanced)
    -XPZ Matched Rods (Staggered?)
    -.020 Coated Pistons
    -180* T-Stat
    I feel like the car should be pushing closer to 400 whp with all these mods but maybe the tuner didn't know what they where doing exactly or maybe I just need to put a smaller pulley on it? I'm only building 12-14 lbs of boost. Its a fun car to drive and handles great between the coil overs and the drilled and slotted F-Body brakes I think it would make a really fun track day car.
    Thanks for the input about the trans too. Didn't know the input shafts liked to break I always thought the drive chain was the "big upgrade" that needs to be done to hold power.
  5. #5 Re: How "built" is my transmission?
    oh the chains stretch.
    you got a few mods alright. that xpz cam likes to eat up timing chains. ive heard it should be changed every 10,000 miles.
    hows the trany fluid looking? smelling? maybe it needs to be tuned, or its knocking on heavens door? thats a fair amount of power going through it.
  6. #6 Re: How "built" is my transmission?
    Kemmerer, Wyoming
    your map sensor maxes out at like 15 lbs of boost, so keep that in mind when you are dropping pulleys. I would drop a pulley and scan for kr and see what happens.
  7. #7 Re: How "built" is my transmission?
    Apr 2015
    Columbus, OH
    Quote Originally Posted by SgtMarshal View Post
    Sure ya would. Then you'd sell it the next week.
    Dang man, nice score! Power numbers do.see.a little low but might not be that far off on a mustang dyno with some left in it. But yeah, I bet it could take more pulley. Like, a lot more pulley on e85.
    Top Swapped 01 Imp
  8. #8 Re: How "built" is my transmission?
    Antioch, IL
    400 no, pending on fuel closer to 360
  9. #9 Re: How "built" is my transmission?
    The Boss Iceman6669's Avatar
    Jun 2011
    Biggest things I from your mod list that I would inquire about are, what injectors are you running? On pump gas I assume? What valve springs are you running?
    Ive known a few guys with similar builds that get good power out of them, and your power #s do strike me as being on the low side. BUT that could be because of the pulley choice. And that could be do to fueling, or some other reason.
    2011 F-150 Yote powered
  10. #10 Re: How "built" is my transmission?
    Sep 2019
    Brownsburg
    Quote Originally Posted by Iceman6669 View Post
    I never looked before but looking now the part number on them 0280155811 makes them the factory injectors. The AFR gauge reads about 12.5:1 while in boost so I suppose the tuner probably just maxed them out and called it a day. And yes it is just running on pump gas right now 89 or 91 depending on whats available. I don't get into it much when its on 89 tho.
    hows the tranny fluid looking? smelling? maybe it needs to be tuned, or its knocking on heavens door? that's a fair amount of power going through it.
    Sucks about the timing chain. I'll have to change that out asap since I don;t know how many miles are on it. Maybe I'll see if there's a performance one available. I'm sure with the extra lift from the cam it'll eat the valves if the chain fails!
    The tranny fluid looks good and smells good. I haven't actually had any issues I was just curious as to how much abuse the transmission would take. I don't hot rod the car when driving for the most part so if I'm just taking it to the track every now and then I guess it'll probably last a while.
  11. #11 Re: How "built" is my transmission?
    it stretches out the double roller timing chains. aka hi performance. that cam needs some HD valve springs and puts a lot of strain on the chain.
  12. #12 Re: How "built" is my transmission?
    Jun 2011
    It can be helped if you run lighter springs on the exhaust side. Not prevented but helped.
  13. #13 Re: How "built" is my transmission?
    May 2008
    Schuyler, NE
    The xpz doesn't eat timing chains.
    You have a few things holding you back. Your transmission is built well, so I wouldn't worry about that.
    You need bigger injectors first off. Look for a set of 60lb injectors with EV-1 connectors. You'll need a tune to be able to run them. It's also a good idea to switch to e85 if you have local access to it, as it adds a ton of cooling to the intake charge.
    Next, you should be running heavier valve springs than that. I run 150# springs on all my XPZ builds. ZZP picked up quite a bit of power switching from 130 to 150 springs. I'm revving my drag car out to 6600 rpms, and power is still climbing at that point.
    Lastly, you'll need to pulley down. A 3.3 will flow limit you to about 400hp at the crank. It is really difficult to put down 400hp at the wheels though. You'll need to add an intercooler to do so.
  1. Replies: 8
    Last Post: 06-25-2015, 06:34 AM
  2. """"""""""3inch Cutout""""
    By PWNED in forum For Sale - Parts
    Last Post: 12-10-2013, 08:10 PM
  3. 2006 Grand Prix "Reduced Engine Power" and "Service Traction System" warnings
    By chadwick in forum General Grand Prix Discussion
    Last Post: 10-04-2013, 09:59 PM
  4. My "Built" GP is slower then my NA GP?? WTH!
    By BlackGT97 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-27-2013, 07:00 PM
  5. "Extra Clips" in 4T65E Transmission Valve Body?
    By agrazela in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-30-2008, 03:17 PM
