Thread: 99 GTP Trans slippage after fluid change, what's next?
Results 1 to 9 of 9
  1. #1 99 GTP Trans slippage after fluid change, what's next?
    May 2018
    Knoxville TN
    I have a 99 GTP with 240K on the clock. Tranny was rebuilt 80K ago and was shifting fine. Last week I replaced the rack and pinion and while I had the car on jacks, I changed the tranny fluid. Used about 5 quarts DEXTRON III, and 2 quarts DEXTRON, and changed out the filter with a Hastings filter I had bought awhile back. Now the car has a developed a slipping problem when accelerating to highway speeds and also on uphill climbs around 35 mph. The slippage seems to be torque converter lock up issues to me.
    What should I do next? I've read that these things can work themselves out as the tranny adjusts to the new fluid. I also was thinking of doing another change and going with an A/C Delco filter instead. And as a last resort was gonna try Lubegard or some sort of additive. Any advice would be appreciated.
    -Thanks!
  2. #2 Re: 99 GTP Trans slippage after fluid change, what's next?
    St. Louis
    Have you verified that the fluid is full? Fully hot trans, in park, running and on level ground.
    Is it the rpms bouncing up and down when you try to accelerate w/o downshifting?
    Beyond that if you're going in again I'd add a trans-go shift improvement kit to it. It won't make it bang the gears just quickens the shifts to minimize clutch wear. I have one in my GT with around 280K on it and it shifts just fine.
  3. #3 Re: 99 GTP Trans slippage after fluid change, what's next?
    May 2018
    Knoxville TN
    Yes she's full. The RPM's do bounce up and down. If move the shifter from D to 3 it stops bouncing.
  4. #4 Re: 99 GTP Trans slippage after fluid change, what's next?
    Apr 2015
    Columbus, OH
    Sounds like a good candidate for a shift kit. Still odd that it started right after an oil change. When was the last time you changed the fluid before this? And I personally wouldn't worry about the filter. Can't see how that would be an issue.
    Top Swapped 01 Imp
  5. #5 Re: 99 GTP Trans slippage after fluid change, what's next?
    May 2018
    Knoxville TN
    The tranny was rebuilt in 2013. Ive put around 75K on it. It is the first time I've changed the fluid since the rebuild.
  6. #6 Re: 99 GTP Trans slippage after fluid change, what's next?
    GT Level Member mguzzo's Avatar
    Buffalo NY
    when I do a trans fluid change I always put in a full quart of Lucas trans fix and then top off with Dex III. It seems to help.
    "Silver Bullet" 98 GTP Coupe: Stock, rust free, and broadsided.
    Old '98 GTP Coupe: VS Cam, 3.0, S2IC, 42.5#, TOGs, N*/LQ4, Corsa. it once ran a 13 flat
    Older '98 GTP Sedan: Pullied, rockered, SSIC, etc. Stock 14.33 @ 96.5 / PB: 13.89 @ 101
  7. #7 Re: 99 GTP Trans slippage after fluid change, what's next?
    sadly at most shops a rebuild is not a full rebuild. they take it apart and replace what was broken and re use all your old crap. like say first gear was slipping, they will replace the 1 st gear clutch packs and nothing more.
  8. #8 Re: 99 GTP Trans slippage after fluid change, what's next?
    May 2018
    Knoxville TN
    Back in 2013 I lost the 3rd/4th band I believe its called. The shop hit me for $650 in parts and $900 in labor. Its been perfect since then.
  9. #9 Re: 99 GTP Trans slippage after fluid change, what's next?
    so in short, your tranny is not rebuilt then, it was repaired. so its got as many miles as the car does still. so your likely slipping. and that means its pretty much over. time to get it repaired again.
    the trans i got in my regal was rebuilt. all wear parts were replaced. seals and such too. all new clutch packs.
    i bought this tranny off a member here who rebuilt a few of them all with good results so far. High(er) performance 4t65e - Sold. What to put on the crate....?
  1. Trans fluid change question
    By Dadillac in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-19-2014, 07:15 AM
  2. Tools/Materials needed for trans fluid change and filter change
    By JDrach in forum General Grand Prix Discussion
    Last Post: 12-10-2012, 07:47 AM
  3. To change trans fluid or not?
    By Elite6 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 11-11-2011, 10:08 AM
  4. How much Fluid for Trans Filter Change
    By dhdolphns in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-06-2011, 03:48 PM
  5. 01 gtp Trans fluid change
    By Draco in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-06-2011, 07:38 PM
