Thread: Gxp trans coolers
Results 1 to 3 of 3
  1. #1 Gxp trans coolers
    Feb 2019
    MN
    Looking at getting a trans cooler for a stock 2005 gxp. Was woundering if anyone knew of a kit for it where i can have it go through rad then into aux cooler then back into trans.
  2. #2 Re: Gxp trans coolers
    Oct 2014
    portland oregon
    You can run a trans cooler either with rad or without rad your call. I eliminated the rad in my case (not GXP) or even the same generation for that matter.
    What cooler to run idk for gxp tho bigger is better I'm told
    Sent from my SM-N920V using Tapatalk
  3. #3 Re: Gxp trans coolers
    Mar 2014
    Tucson
  1. Tranny Coolers-
    By GTByron in forum Introductions/Noob Questions
    Last Post: 04-03-2013, 09:42 PM
  2. Trans coolers
    By BlackGT97 in forum General Tech Discussion
    Last Post: 01-23-2012, 12:41 PM
  3. For those with aftermarket/Aux. trans coolers...
    By Wotgtp in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-05-2011, 03:18 PM
  4. need advice about trans coolers.
    By kirkkarem1212 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-28-2010, 04:40 PM
  5. Tranny coolers
    By hypnos in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 10-15-2009, 05:50 PM
