Thread: 2000 GP GT won’t leave first...
Results 1 to 5 of 5
  1. #1 2000 GP GT won’t leave first...
    Oct 2018
    NC
    I have a 2000 Pontiac Grand Prix that will go into park, reverse and drive no problems. Once on the road, though, it won’t shift out of first gear. Linkage is fine I assume because it does cycle through all gears (I can hear it go into place) and I replaced the filter and fluid (the fluid was not low but smelled a bit of burned plastic) already to no avail. I don’t want to think the clutches are bad, because before it started doing this the car ran and shifted with no problem... What’s your take?
  2. #2 Re: 2000 GP GT won’t leave first...
    St. Louis
    When you replaced the filter did you get the old o-ring out of the valve body before you installed the new filter? If not then the filter could be loose and not getting enough fluid into the trans. Also, when you refilled it, did you check it while it was fully hot, in park on a level surface? Does it whine at all or make other odd noises it did not before you changed it?
  3. #3 Re: 2000 GP GT won’t leave first...
    Oct 2018
    NC
    I did get the old o-ring out and it was in quite securely! I went through the original service procedure for checking fluid level. The transmission pump does have a bit of a whine but it always has... I assume I would have seen symptoms (hard shifting or otherwise) prior to the car refusing to shift out of first altogether...
  4. #4 Re: 2000 GP GT won’t leave first...
    Oct 2018
    TX
    Sorry bud if your fluid is burned that's no good. I had the same issue with my 2002 GTP replaced the trans no more problems best of luck to ya
  5. #5 Re: 2000 GP GT won’t leave first...
    Your post sounds as if you one day had this problem, then did the fluid change/service. Is that correct?
    You mention it won't come out of first gear, roughly what rpm are you at around 30 mph? Are there any check engine lights?
    If the rpms are low at 30mph it would suggest you are stuck in 3rd gear only. This is typically caused by not getting power to the transmission soleniods and suggests a rubbed wire or blown fuse. If the rpms are high and you are indeed in 1st, then you have power to both solenoids and likely there is a different issue which possibly could be a trans rebuild/replacement.
  1. P0440 won't Leave lol
    By Bluemagic in forum General Grand Prix Discussion
    Last Post: 08-07-2013, 06:28 PM
  2. I'll just leave this here
    By Sandman in forum General Grand Prix Discussion
    Last Post: 08-21-2012, 09:06 PM
  3. Polys: Leave em in or take em out?
    By BwolfGT in forum General Tech Discussion
    Last Post: 03-25-2011, 02:02 AM
  4. I'll just leave this here
    Last Post: 10-13-2010, 07:12 PM
  5. Leave it in Gear??
    By copterdoctor in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-04-2009, 07:27 PM
