Thread: Reset ECM after transgo install?
Results 1 to 4 of 4
  1. #1 Reset ECM after transgo install?
    St. Louis
    Finally got around to changing the fluid/filter and installing the TEP transgo kit. Got it all filled up and it shifts fine through all gears. Which is promising since I was afraid I screwed up the accumulator install, lol. Anyways, since this trans would set the P1181 code after stop and go driving in rush hour occasionally and start banging shifts, would it be best for me to dump the battery for a bit and let it re-learn or will it figure it out on it's own?
  2. #2 Re: Reset ECM after transgo install?
    I'd clear any codes and let it learn from scratch.
    So yeah, unhook the battery for a while.
  3. #3 Re: Reset ECM after transgo install?
    Oct 2011
    Toledo, OH
    If I recall, don't the instructions actually say you should disconnect the battery anyway?
    7"
  4. #4 Re: Reset ECM after transgo install?
    St. Louis
    Didn't see it mentioned in the instructions but I'll go ahead and dump the battery anyway. Thanks guys!
  1. DIY How To Install TransGo Shift Kit 4T65E Very Detailed+Pictures
    By 02NavyBlue in forum How To Write-Ups/Tech Tips
    Last Post: 07-09-2023, 03:55 PM
  2. Should I install a Transgo Shift Kit 4T65-E?
    By TheRiGuy in forum General Grand Prix Discussion
    Last Post: 02-14-2017, 10:52 AM
  3. transgo s/k
    By blackthunder in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-25-2014, 06:16 PM
  4. Transgo Shift Kit Install Help
    By matthew911 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 09-15-2012, 06:22 PM
  5. transgo shift kit install Q
    By GTPJOE90 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-10-2012, 11:19 AM
