Thread: Engine Support for Transmission Swap
Results 1 to 7 of 7
  1. #1 Engine Support for Transmission Swap
    SE Level Member green97's Avatar
    Jul 2011
    Eastern Idaho
    Alright I have seen the how to write ups found from searches. However none of the photos work due to photobucket BS. Any body have pics of their home made engine supports? Was hoping to see what bill boost made out of a 4x4.
    I bought a harbor freight Pittsburgh engine support bar but I don't like how there is no support bar for front to back support. If I can build my own I would like to take this back for a refund.
    When using a support bar homemade. Do you have to jack the engine up from the oil pan to get the chains tight enough to hold the motor?
    Am I better off using my cherry picker to pull engine and transmission again instead of tranny out the bottom?
  2. #2 Re: Engine Support for Transmission Swap
    i used my engine hoist to hold the engine up. pushed it in from the pass side fender.
  3. #3 Re: Engine Support for Transmission Swap
    Jul 2011
    Eastern Idaho
    I guess I will have to check that the legs don't reach under the trans. Not sure I have enough jack stand height to get the cradle out with picker legs under it. Do you know how high you went with the jack stands if you used them?
  4. #4 Re: Engine Support for Transmission Swap
    i put my floor jack under the middle front sub frame and maxed it out, then put the stands under the rockers. you got enough room. i was doing a tranny swap myself. hoist is what i had on hand that i knew would work.
    link to pic http://i1097.photobucket.com/albums/...pstalc3ubp.jpg
  5. #5 Re: Engine Support for Transmission Swap
    Aug 2011
    'Merica
    This is what we used.
  6. #6 Re: Engine Support for Transmission Swap
    GTX Level Member cheatah faheatah's Avatar
    May 2016
    Rouge Island
    PB B.S., both of yous^^^^
    For the record : I am NOT a naked meth-head who shoves rocks up my butt.
  7. #7 Re: Engine Support for Transmission Swap
    Aug 2011
    'Merica
  1. Engine swap / Trans swap 2001 gtp v. compatible years
    By Banana Hammock in forum General Grand Prix Discussion
    Last Post: 07-06-2016, 08:27 AM
  2. L67 Engine/transmission swap into L36
    By tharrill in forum General Grand Prix Discussion
    Last Post: 07-02-2013, 05:02 PM
  3. Engine and Transmission swap from an 04 to a 99 GP
    By 99metalicgtp in forum Introductions/Noob Questions
    Last Post: 07-27-2012, 12:58 PM
  4. Overhead engine support
    By Phyrstorm in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-19-2011, 01:59 PM
  5. Got A Dilema, Which Engine Support
    By SyntheticShield in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-04-2008, 06:03 PM
