Thread: Issue: 07' Grand Prix Base Will Start But Will Not Change Gears
Results 1 to 5 of 5
  1. #1 Issue: 07' Grand Prix Base Will Start But Will Not Change Gears
    SE Level Member PontiacZack's Avatar
    Jun 2016
    San Antonio, TX
    Good Evening, all I'm trying to troubleshoot the situation with my 07' Pontiac Grand Prix Base. I come to seek advice, if this ins't the proper board to post this on, I'm sorry in advanced.
    To Elaborate:
    Earlier today, I left my house like normal, the car started fine and I was on the go. I reached my destination and when I went to leave the car started as normal, I put it into Drive hit the gas and nothing happened. So, I put it into Reverse and got the same results. One, thing I have noticed though is that I now have the ability to move my gear shifter freely without pressing down handle up at least 2 marks. For example, If I am in Drive, I am able to go to Reverse. Also, to note I haven't heard any strange noises running through the car either.
    Questions I have:
    Does anyone know what it could be?
    Have you ever had this issue? How did you fix it?
    What should I be checking for?
    What would you do in this situation?
    Or am I S.O.L? Will I need a new tranny?
    Things I've done so far:
    >Looked under the car for any leakage (No transmission fluid was leaking)
    >Checked Transmission fluid and it was a dark color and not pinkish red
    >Took off the center console to verify everything was hooked up properly
    Thank you for taking the time to read through this post.
  2. #2 Re: Issue: 07' Grand Prix Base Will Start But Will Not Change Gears
    will it move it you put it in 1 st gear manually? will it go in neutral?
    if your lucky the plastic clip broke off the tranny at the cable end, worst case the forward band broke. dark fluid is never a good sign.
  3. #3 Re: Issue: 07' Grand Prix Base Will Start But Will Not Change Gears
    See if the linkage off the transmission broke, the plastic ball piece can crack and break and cause the shifter to not move on the transmission anymore.
    Should look like this on top of the transmission, inbetween the exhaust and master cylinder.
  4. #4 Re: Issue: 07' Grand Prix Base Will Start But Will Not Change Gears
    Jun 2016
    San Antonio, TX
    Thank you guys for the replies, it's some really helpful information. I was able to get the issue fixed. I want to give BIG thank you to Fivefingerdeathpunch! That's exactly what the issue was. The grommet had broken off and the piece was unhooked. I went and got a grommet and hooked the piece back on.
  5. #5 Re: Issue: 07' Grand Prix Base Will Start But Will Not Change Gears
    GTX Level Member cheatah faheatah's Avatar
    May 2016
    Rouge Island
    Isn't it great when the solution turns out to be the easiest, simplest, and cheapest ? Savor those victories.
    For the record : I am NOT a naked meth-head who shoves rocks up my butt.
  1. 06 Base Rough Start with Auto Start
    By jenebo in forum 04+ Specifics
    Last Post: 08-30-2016, 11:24 AM
  2. 2008 Grand Prix Base Possible injector issue Code P0305
    By smoraq in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-24-2016, 04:22 PM
  3. Joe's '08 Grand Prix Base
    By joeringo11 in forum Members Rides
    Last Post: 07-06-2012, 02:08 PM
  4. 05 grand prix base
    By kmk2005 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-22-2011, 04:53 PM
  5. 2008 Grand Prix no start issue
    By supernac in forum General Tech Discussion
    Last Post: 08-22-2010, 11:57 AM
