Thread: Trans/Differential problem
Results 1 to 3 of 3
  1. #1 Trans/Differential problem
    Feb 2009
    Leonard TX
    I have an 02 GT with about 120k and it has a bad vibration coming from the front right when I accelerate. Feels like the wheel is about to fall off. Thought it was bad tire or wheel balance but I rotated at balanced them. The problem is still there. I jacked the car up and put it in gear it the axle is moving up and down near the trans while in drive. The cv joints seems good. Its not clicking and boots are in good shape. Could it be the axle is bad or maybe the differential bearings? Wheel bearings maybe?
  2. #2 Re: Trans/Differential problem
    Transmission Expert Trannyman95's Avatar
    Fort Wayne, IN
    Check all of the suspension components and also the outer tie rod ends to make sure they are not sloppy. If the car is lowered you can also have a driveline vibration while accelaring.
  3. #3 Re: Trans/Differential problem
    Feb 2009
    Leonard TX
    I replaced the right axle and problem solved
  1. EP Differential??
    By Iron Indian in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-01-2020, 07:46 PM
  2. trans problem in a 00 gtp
    By 98GTPON22s in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-25-2009, 05:16 PM
  3. 98 GT Trans Problem
    By 98GTKen in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 12-14-2008, 09:47 PM
  4. Trans problem with 96 Grand Prix - need a little help, please
    By Boatman in forum Pre-1996 4 speed Automatic (4T60E)(4T60E-HD)
    Last Post: 05-03-2008, 08:53 PM
  5. Trans problem - 96 Grand Prix
    By Boatman in forum General Tech Discussion
    Last Post: 05-03-2008, 05:26 PM
