Good Evening, all I'm trying to troubleshoot the situation with my 07' Pontiac Grand Prix Base. I come to seek advice, if this ins't the proper board to post this on, I'm sorry in advanced.
To Elaborate:
Earlier today, I left my house like normal, the car started fine and I was on the go. I reached my destination and when I went to leave the car started as normal, I put it into Drive hit the gas and nothing happened. So, I put it into Reverse and got the same results. One, thing I have noticed though is that I now have the ability to move my gear shifter freely without pressing down handle up at least 2 marks. For example, If I am in Drive, I am able to go to Reverse. Also, to note I haven't heard any strange noises running through the car either.
Questions I have:
Does anyone know what it could be?
Have you ever had this issue? How did you fix it?
What should I be checking for?
What would you do in this situation?
Or am I S.O.L? Will I need a new tranny?
Things I've done so far:
>Looked under the car for any leakage (No transmission fluid was leaking)
>Checked Transmission fluid and it was a dark color and not pinkish red
>Took off the center console to verify everything was hooked up properly
Thank you for taking the time to read through this post.
