Thread: Transmission dipstick tube disconnected.
Results 1 to 9 of 9
  1. #1 Re: Transmission dipstick tube disconnected.
    GTP Level Member buickman104's Avatar
    NYC
    The tube is held in with a single bolt to the back of the transmission. I had my dipstick break when the welded bracket to the tube rusted and broke leaving a hole. Figure out if it is the bracket that rusted and separated or the grommet in the transmission that the tube goes into.
    2000 Bronze Metallic GTP
    Power :Gen V, 3.6 pulley, 3 inch down pipe, Power log, FWI,and DHP Power Tuner,
    Handling: Vogtland Springs, GMPP sway bars, STBS, 18" Konig backbone, CTS-V Front brakes and GXP rear brakes
  2. #2 Re: Transmission dipstick tube disconnected.
    Jun 2013
    Glendale, AZ
    Quote Originally Posted by buickman104 View Post
    Thank you, I will check it out tonight. How easy is that bolt to get to?
    Sent from my Nexus 6P using Tapatalk
  1. How to bend transmission dipstick
    By snj111795 in forum Introductions/Noob Questions
    Last Post: 08-25-2015, 07:40 AM
  2. Oil dipstick tube
    By chevyy1212 in forum General Tech Discussion
    Last Post: 08-26-2011, 09:46 AM
  3. HELP! Little piece of dipstick fell into oil tube/reservoir
    By Noopsky13 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-26-2011, 07:19 PM
  4. Modified Trans Dipstick tube from Intense...
    By Iron Indian in forum Off Topic Discussion
    Last Post: 02-22-2008, 07:54 PM
