Thread: Using Hard Drive Magnets in Pan?
Results 1 to 3 of 3
  1. #1 Using Hard Drive Magnets in Pan?
    SE Level Member Moozery's Avatar
    Apr 2016
    Ontario
    I've read about upgrading transmission pan magnets, and if I'm not mistaken I read that the new GM ones are neodymium.
    I was wondering if you guys see anything wrong with just using old hard drive magnets instead?
    They're just neodymium with some sort of coating on them.
    Just wasn't sure if they'd be too strong or what could happen to that coating under high temperature.
    I have a dozen of these things and I figured I could save a few bucks.
  2. #2 Re: Using Hard Drive Magnets in Pan?
    HUDSON
    Them suckers are strong! Just stick them to the underside of the pan, that way you don't have to worry about clearance issue having them on the inside of the pan.
  3. #3 Re: Using Hard Drive Magnets in Pan?
    SE Level Member Transman304's Avatar
    Jan 2017
    West Virginia
    It will be fine for your application. Not good for a transmission that has electronic parts in the pan. You'll be able to catch the big pieces��
    Brad
    "If you can't fix it with a hammer you have an electrical problem"
    Like us on Facebook @ " Otto Matics"
  1. all wheel drive drive rain with 3.8 engine
    By fisheson in forum General Grand Prix Discussion
    Last Post: 03-11-2016, 12:13 PM
  2. GXP clunk from park to drive, drive to reverse..
    By sasquatch094 in forum General Tech Discussion
    Last Post: 02-13-2014, 04:27 PM
  3. Magnets on fuel rails?
    By BlackGT97 in forum General Tech Discussion
    Last Post: 01-23-2012, 06:37 PM
  4. External hard drive
    By joshua_arndt in forum Off Topic Discussion
    Last Post: 10-10-2009, 06:39 PM
