Thread: Transmission Questions
Results 1 to 13 of 13
  1. #1 Transmission Questions
    May 2013
    Minnesota
    Hi all. Just bought a 2004 GTP Comp G!! It's got 205,657 miles. my question is. The transmission fluid is orange and it smells burnt. It did slip alittle but it was low on transmission fluid so I added some hasn't done it since. I'm just wondering i was thinking of dropping the pan and adding new fluid till it was full again. My question is with this much miles is it worth doing? I'm just afraid I always hear if it's got high miles and shifts fine leave it alone.
  2. #2 Re: Transmission Questions
    May 2008
    Schuyler, NE
    With those miles, I'd leave it alone. At this point, you probably won't get any more miles out of it by dropping the pan versus leaving it.
  3. #3 Re: Transmission Questions
    St. Louis
    Why not try a pan drop/filter change and install a shift kit? Could be just a clogged up filter.
    Even if you only drop the pan and change the filter you're only out the 7-ish quarts of fluid + filter. As long as the fluid isn't black already it'll probably live a bit longer even with the mileage on it. I pan dropped my 00GT around 230K on a used trans and so far it's still working fine. I figured if it was already cooked then I've just got that much more out of it at this point when it does finally eat itself, lol..
  4. #4 Re: Transmission Questions
    GTX Level Member EJOUIE's Avatar
    Newnan, GA
    I would reccommend posting a photo of the fluid. Then making your own decision based on the responses.
    Sent from my SM-G920P using Tapatalk
    97 GT white 4 door-SOLD
    Cherry 2005 Impala LS- Front and Rear GMPP Strut Tower Braces
  5. #5 Re: Transmission Questions
    May 2013
    Minnesota
    Quote Originally Posted by EJOUIE View Post
    Transmission Questions Attached Images
  6. #6 Re: Transmission Questions
    run it till it takes a crap, in the mean time, start saving/planning for a replacement. with those miles and the color of that fluid, it owes you nothing. its been around a long time already.
    i got my car at 212,000 tranny felt pretty good, but the fluid was also black. it lost 3 rd gear for no reason @216,000 miles. went used, only got about 20,000 miles out of that one, now im 500 miles deep on a full rebuild.
    so i killed two trannys so far. all with in 30,000 miles. not a fun club to be in. granted, ive had the car about 7 years now and dont pound the miles on. so its not like they failed asap on me.
  7. #7 Re: Transmission Questions
    Newnan, GA
    That fliud color looks exactly like what I found in my old grand prix when I checked it for the first time. It did not smell burnt though. I changed the fluid several times over the following 90,000 miles. It was shifting good as new still when I traded it in.
    The color could very well be due to the age of the fluid. 205k miles on 14 yr old fluid could definitely cause some funny transmission issues.
  8. #8 Re: Transmission Questions
    Mar 2017
    West Virginia
    what kind of fluid???
    what shift kit?????
  9. #9 Re: Transmission Questions
    SE Level Member Billycar11's Avatar
    Apr 2015
    Pa
    if your 05+ most say Valvoline dex vi https://www.amazon.com/Valvoline-DEX...line+dexron+vi
    for older transmissins look for something dex III compatible
    and the shift kit is transgo https://www.amazon.com/Wellington-Pa...hift+kit+4t65e
  10. #10 Re: Transmission Questions
    Mar 2017
    West Virginia
    thanks
  11. #11 Re: Transmission Questions
    I can't car too good. SaukRapids's Avatar
    May 2016
    MN
    You might've seen this thread. Lots of tips and info in there for the trans-go. http://www.grandprixforums.net/threa...ailed-Pictures
  12. #12 Re: Transmission Questions
    GT Level Member mguzzo's Avatar
    Buffalo NY
    change it and keep driving.
    "Silver Bullet" 98 GTP Coupe: Stock, rust free, and broadsided.
    Old '98 GTP Coupe: VS Cam, 3.0, S2IC, 42.5#, TOGs, N*/LQ4, Corsa. it once ran a 13 flat
    Older '98 GTP Sedan: Pullied, rockered, SSIC, etc. Stock 14.33 @ 96.5 / PB: 13.89 @ 101
  13. #13 Re: Transmission Questions
    May 2013
    Minnesota
    Only issue I'm having. Is when i kick it down on the highway. It will rev and then kick into gear. Does that mean. The transmission is on its way out? Sometimes when turning it does that too slips and kicks into gear
  1. Transmission questions
    By wannabegtp in forum General Tech Discussion
    Last Post: 05-29-2015, 06:41 PM
  2. New Guy here few questions, transmission
    By thanospl in forum General Tech Discussion
    Last Post: 08-03-2010, 09:47 AM
  3. My Transmission questions???
    By JDCMoney in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 10-26-2009, 12:55 PM
  4. have 2 transmission questions
    By 98GTPON22s in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-02-2009, 05:17 PM
  5. Transmission questions.
    By ChvyTrcksFrdScks in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-22-2008, 07:11 PM
