Thread: 4t65E valve body bolts
Results 1 to 12 of 12
  1. #1 4t65E valve body bolts
    Feb 2017
    NH
    Does any one have a diagram or link of the bolts lengths? There are 3 or more different lengths. I do have torque specs, but I'd love it if I could have a length diagram. I will be remove my valve body today. I am new to this forum and I cannot find a search box. In the mean time I will take lots of pics and measure everything off.
    2002 Park Avenue Ultra 3800 supercharged.
  2. #2 Re: 4t65E valve body bolts
    May 2008
    Schuyler, NE
    Do you have the rebuild manual?
  3. #3 Re: 4t65E valve body bolts
    Feb 2017
    NH
    No, I am going off all-data and consensus on line. I am changing out the solenoids and the 4th clutch hub.
    Today I pulled the valve body and separator plate. Since I didn't have a printed guide on the bolts I used the information I did have to identify them. So that's done. It just took some extra time.
    I replaced the 4th clutch hub with a hardened spline one. Now I am reassembling things and some questions have come up. When I separated the valve body from the cover plate 2 small check balls came loose along with a hollow roll pin sorta piece. I still am going to fish in my catch pan to see if any thing else popped out. I am going to screen it as I pour it off.
    I am about to search for those ball's and pin's locations.
    I have to source and order a trans wiring harness because I gorilla'd 2 of the keepers that secure the plugs in the left side of the valve body. And I have to get a fluid dam because I slipped while installing the plate and broke the dam.
    I'm doing some searching now. If any one on here is sharp on these items I'd appreciate any guidance or ideas to move me along.
  4. #4 Re: 4t65E valve body bolts
    crap-ola you leave a few bolts in and the whole valve body comes out as one part, so it wont split and let the balls come out of place.
    damn this was a fight for even me to find. http://www.grandprixforums.net/threa...e-cover-access
  5. #5 Re: 4t65E valve body bolts
    Feb 2017
    NH
    I finally found the tiny little search prompt. It's top right.
    Thanks for digging out the spot on the balls though.
  6. #6 Re: 4t65E valve body bolts
    that search thing sucks here, best to use google start your search with "grandprixforums" then what your looking for. if you know the thread name, or the persons s/n who posted, add that and things come up much faster.
  7. #7 Re: 4t65E valve body bolts
    Feb 2017
    NH
    Great idea. thanks.
    Now I have to find out how to reassemble the things I shouldn't have unbolted.
    What a dope I was, I had that thread in my mind and didn't remember where it was.
  8. #8 Re: 4t65E valve body bolts
    theres a few guys here who have fully rebuilt trannys and have the diagram for the v/b. im sure they will find your thread soon.
    theres also a few full rebuild vids on you tube.
  9. #9 Re: 4t65E valve body bolts
    Feb 2017
    NH
    So I'm doing OK. I found a checkball chart. But that piece I called a hollow drift pin is more likely a bushing. Still gotta determine where it belongs.
    Looks like I might be ordering a rebuild book.
  10. #10 Re: 4t65E valve body bolts
    some one here did a vid as well, just came to mind, as he takes it apart hes bagging tagging everything.
    just found this, thanks google lol http://www.gmforum.com/4t65e-hd-147/
  11. #11 Re: 4t65E valve body bolts
    found this one too http://pontiacbonnevilleclub.com/for...php?f=8&t=1483 its got pics of the check balls in place with trans goop in the one 1/2. pic are down at the bottom of the vb install part of it all.
  12. #12 Re: 4t65E valve body bolts
    Feb 2017
    NH
    Thanks.
    I found it in the ATSG service manual. The piece I was trying to find actually IS a locating pin. For future reference if any one comes across this string, it's on page 38 of the ATSG manual figure 51 and it's item 410. Whew!
  1. looking for arp head bolts and ear valve cover for l32
    By Warriorpluto in forum Wanted To Buy - Parts
    Last Post: 04-26-2016, 03:32 PM
  2. 4T65E Check Valve Fitting
    By Impala131 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-27-2015, 10:26 AM
  3. 3800 SC Valve Cover Bolts?
    By JaguarRD in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-06-2013, 10:43 AM
  4. valve cover bolts
    By kawasakidrivinghick in forum Wanted To Buy - Parts
    Last Post: 02-19-2013, 07:46 AM
  5. "Extra Clips" in 4T65E Transmission Valve Body?
    By agrazela in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-30-2008, 03:17 PM
