Thread: tranny rpm surging/bouncing from 3-4 to overdrive, possible faulty brake switch?
Results 1 to 2 of 2
  1. #1 tranny rpm surging/bouncing from 3-4 to overdrive, possible faulty brake switch?
    Jul 2015
    indianapolis
    hey guys ever since i bought this car ive always noticed that when going 50-60mph going from 3-4-overdrive that the rpms would surge and kick it back into 3rd then it would repeat that process. the cars history states that the transmission was overhauled by ammco transmissions at 95,000 miles and it only has 139,000 on it now ive barely put any miles on it. i read on gtpworld forum that it could be a faulty brake switch sending a signal to the tcc to lock up when the brake pedal isnt even being touched, i was wondering which switch would it be on the brake pedal as i have one with 2 connectors and one with only 1 connector? thanks
  2. #2 Re: tranny rpm surging/bouncing from 3-4 to overdrive, possible faulty brake switch?
    SE Level Member Transman304's Avatar
    Jan 2017
    West Virginia
    Sounds like stripped splines on the 4th clutch hub.
    tranny rpm surging/bouncing from 3-4 to overdrive, possible faulty brake switch? Attached Images
    Brad
    "If you can't fix it with a hammer you have an electrical problem"
    Like us on Facebook @ " Otto Matics"
  1. Brake lamp switch
    By Jnibbs24 in forum General Grand Prix Discussion
    Last Post: 10-09-2015, 07:26 PM
  2. Problem with brake safety switch
    By Jordanmccarty in forum General Tech Discussion
    Last Post: 03-03-2012, 10:38 AM
  3. brake switch bad
    By threegtoman in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 12-28-2010, 12:05 PM
  4. Trans switch/ e brake switch
    By Halbs in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-20-2010, 02:57 PM
  5. Tranny shifts from 2nd gear to Overdrive?!?!?
    By atrainbynight in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 11-24-2009, 04:14 PM
