Thread: Do trango shift kits wear out?
Results 1 to 9 of 9
  1. #1 Do trango shift kits wear out?
    Jul 2014
    New Jersey
    I put in a transgo kit in a 2002 3.8 gt. The kit now has 100,000 miles on it and I am getting intermittent hard shifting and shuttering in 3-4 gears , this happens once a week and other times the car runs fine. I also get the p1811 code
    Could this be my shift kit wearing out? Or is it another problem ?
  2. #2 Re: Do trango shift kits wear out?
    sounds like the tranny is wearing out, try some trans medix type stuff, might help. you can suck a quart out via the dip stick tube with clear tubing easy enough so you dont over fill it.
  3. #3 Re: Do trango shift kits wear out?
    Mar 2014
    Tucson
    The PCS may be on it's way out. At that mileage, could be either.
  4. #4 Re: Do trango shift kits wear out?
    GTX Level Member EJOUIE's Avatar
    Newnan, GA
    How old is the fluid?
    Sent from my SM-G920P using Tapatalk
    97 GT white 4 door-SOLD
    Cherry 2005 Impala LS- Front and Rear GMPP Strut Tower Braces
  5. #5 Re: Do trango shift kits wear out?
    Jul 2014
    New Jersey
    4years about 80,000 miles, I changed it when I put the shift kit in, it is still nice and red
  6. #6 Re: Do trango shift kits wear out?
    Donating Users NotEnoughGPs's Avatar
    Aug 2013
    Pittsburgh, PA
    Quote Originally Posted by BrandonHall10 View Post
    I got some homework for you!
    Best read, I mean the very best reading you can find on the 4T65E and 4T65E-HD transmissions is TEP website:
    http://www.tripleedgeperformance.com...ift-P1811.html
    And find someone with HPTuners (or buy HPT and check the website for instructions on how to make adjustments to the PCM) A tune with increased line pressure will solve this issue. I had the same hard shifting issue on my 40th Anniversary and a tune took care of it
  7. #7 Re: Do trango shift kits wear out?
    Newnan, GA
    With 80,000 miles on the fluid, a change would help. Every 50,000 generally is recommended.
    Probably not the full story, but worth a shot.
  8. #8 Re: Do trango shift kits wear out?
    Jul 2014
    New Jersey
    Thanks for all the info, this week I took it to Aamco and they told me solenoids were fine and that it could be something bad, so they suggested $1850 to rebuild the transmission, I told them forget it. When to an independent, told him the situation , he said start looking for a new car. Not worth the expense for a 2002 with 217,000 miles. Symptoms are pointing at pressure control solenoid. I am going to try and change that in the next few days.
    any tips or advice?
  9. #9 Re: Do trango shift kits wear out?
    Mar 2014
    Tucson
    Get the Borg Warner PCS.
    http://shop.tripleedgeperformance.co...2002-33946.htm
    It can be had cheaper from other sources, but TEP is a preferred vendor here so that's the link I gave. Also, when you do the solenoid, you're about 75% of the way to the 4th clutch hub.
  1. suggestions on shift kits
    By Alexgp in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-14-2016, 02:22 PM
  2. Dumb n00b question... shift kits vs. reprogramming
    By bobc455 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-13-2015, 07:12 AM
  3. shift kits
    By winterstorm in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-15-2012, 09:07 PM
  4. shift kits?????
    By imdaman3 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-16-2010, 12:35 AM
  5. Shift kits...
    By Bogers99GTP in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-03-2008, 12:34 PM
