Thread: Need Help diagnosing tranny problem.
Results 1 to 5 of 5
Threaded View
  1. #3 Re: Need Help diagnosing tranny problem.
    Jan 2009
    Shawano, WI
    Thank You Trannyman.
    I turned the car on today and let it run for 20 minutes. Then I shifted slowly through the gears Reverse works fine still and so does 1st and 2nd gear. Third gear and drive still do nothing.
    Maybe this can help diagnose the problem. When I'm in reverse and when I put it in neutral the headlights and dashlights get dimmer and then when I move it to drive the lights come back to full brightness and the engine revs up to about 1000 rpms then settles back down, it does not do this from drive to 3rd gear.
    Could this be electrical?
  1. Tranny Problem
    By 2000GTP2708 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 10-24-2008, 02:48 AM
  2. diagnosing fuel leak
    By Toasty in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-19-2008, 03:27 AM
  3. 1995 GP Tranny problem
    By zayuh in forum Pre-1996 4 speed Automatic (4T60E)(4T60E-HD)
    Last Post: 05-10-2008, 07:09 PM
  4. Weird tranny problem
    By 04CompG in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-03-2008, 07:51 AM
  5. Diagnosing corrosion on coil pack terminals
    Last Post: 01-30-2008, 01:52 PM
