Thread: What are the normal cruising rpms?
Results 1 to 7 of 7
  1. #1 What are the normal cruising rpms?
    Sep 2015
    Lansing, Michigan
    I noticed today that when going anywhere from 25-45 mph when at operating temperature (basically city driving):
    Foot lightly on gas - rpms go up to 2500,3000
    Foot off gas - rpms drop to about 1,100 going any of those speeds mentioned above.
    I sit parked idling at about 800-900 rpms.
    Is this normal?
  2. #2 Re: What are the normal cruising rpms?
    Jul 2010
    Coquitlam,BC,Canada
    Quote Originally Posted by tom5170 View Post
    Those RPM's are s little hi for 25-45. Everything else looks normal.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  3. #3 Re: What are the normal cruising rpms?
    Sep 2015
    Lansing, Michigan
    They drop to 1,100 at 20-40 mph when I take foot off gas and just coasting
  4. #4 Re: What are the normal cruising rpms?
    Jul 2010
    Coquitlam,BC,Canada
    That is normal. I hate that it does that because you lose engine braking at that point.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  5. #5 Re: What are the normal cruising rpms?
    GXP Level Member
    Mar 2015
    Tomball
    I only run about 1100-1200 in 3rd locked up at 40. I run about 1900 at 70 locked up in 4th.
    Between 20-30 and varying the gas it isn't going to lock up and you are at the bottom of 3rd gear at that point, so the TCC is slipping about 600-700 rpm's when it locks up about 35 or so then it will drop TCC slippage to about 20-30rpm
    Jeff
  6. #6 Re: What are the normal cruising rpms?
    Sep 2015
    Lansing, Michigan
    Alright cool so all good then?
  7. #7 Re: What are the normal cruising rpms?
    GT Level Member brettstoner's Avatar
    Jul 2014
    Toledo, OH
    From a stop.... Light throttle, watch for the car to shift to 2nd, 3rd, 4th, then lockup. Say at 48-50 car should stay locked in OD with light throttle. Give it medium-light throttle should unlock, stay in 4th, jump up several hundred rpm. More throttle medium-heavy and get the downshift to 3rd.
    You should (flat level road) be able to keep it locked in 4th in light throttle at 50 mph cruise steady state around 1500 rpm (depending on gearing).
    Normal driving (ie light acceleration) I shift around 2,000-2,500 rpm and cruise around 1,400 (depending if I am going fast enough to lock 4th OD). 100% city.
  1. Throttle dip while cruising.
    By Timing in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-01-2014, 07:42 PM
  2. RPMs bouncing when cruising
    By nukkinfuttz in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-10-2012, 07:05 AM
  3. Highway Cruising
    By JDCMoney in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 10-20-2009, 03:31 PM
  4. kr at cruising???
    By orange97gtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-02-2009, 10:20 AM
  5. Few kills just cruising around..
    By Bogers99GTP in forum Track Sessions and Kills
    Last Post: 11-02-2008, 10:20 PM
