Thread: 4T65E-HD RPM Drops
Results 1 to 11 of 11
Threaded View
  1. #1 4T65E-HD RPM Drops
    SE Level Member Felix's Avatar
    Jul 2016
    On my 2002 GP GTP it makes a noise that is supposedly coming out of the transmission (Sort of like a single hit from two metal object), when I'm in the car it sounds like its coming from the right side of the vehicle. Also when I switched from park to reverse I notice the RPM sometimes drops from 1000 all the way down to 500, haven't noticed that before. Park to drive I notice that it does not make a noise and the rpm does not drop. Is that my reverse going out?
    EDIT: The noise only happens when I'm switching to reverse, also when I'm at parked at an angle it becomes extremely stiff and needs a bit of force to switch the car from park to reverse.
    EDIT: Already replaced both CV axles and trans/engine mounts.
    EDIT: Need to replace tie rods and wheel hubs.
  1. temp goes to right below red and then drops to 180
    By csanderlin in forum 3.1L V6 (LHO/LG8)
    Last Post: 01-08-2013, 01:11 AM
  2. Tach drops to zero
    By ahill261 in forum General Grand Prix Discussion
    Last Post: 10-05-2012, 10:11 PM
  3. RPM drops above 45 mph
    By guyute85 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-09-2011, 01:58 AM
  4. 01 gtp misfire and rpm drops
    By samuelcb409 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-29-2011, 04:54 PM
  5. rpm drops
    By PhunnyJesta in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-13-2011, 06:16 PM
