Thread: 284 fail. 4t80e possibly inc.
Results 1 to 20 of 33
  1. #1 284 fail. 4t80e possibly inc.
    gardner,mass
    Ok so since my 284 swap was a fail and i have to convert the car back to Auto. I am thinking about a 4t80e swap. I have read through what is listed here on the thread. But am looking for more in detail help.
    This will be bolted to an L32 in a 2004 grand prix. Car is daily driven so i want the trans to be controlled as factory if even possible. What axles do i need? Pretty sure ill need headers cut/rewelded for the bigger trans. Mounts i can fab. Is there going to need to be any body modifications done to fit the trans?
    Trying to collect as much useful information as possible.
    RPF1 17x9 255/45 Direzza Zll
    04 COMPG- Vs, getrag 284 RIP
  2. #2 Re: 284 fail. 4t80e possibly inc.
    GTP Level Member
    Apr 2012
    Las Vegas, Nv
    Subscribed.
    GPONA #1 Cyber Bully
  3. #3 Re: 284 fail. 4t80e possibly inc.
    Oct 2011
    Toledo, OH
    Quote Originally Posted by blackspike2710 View Post
    Subscribed.
    Ditto
    7"
  4. #4 Re: 284 fail. 4t80e possibly inc.
    I break stuff selliott's Avatar
    Kansas City
    Ask vet he has a ton of info on the 80 swap. Also Dave at TEP has done the swap. What happened to the 284?
  5. #5 Re: 284 fail. 4t80e possibly inc.
    Quote Originally Posted by selliott View Post
    lunch.
    that new vendor furches just did a 80 swap im sure hes got some info on tuning or somehow to make it work seamlessly and parts lists needed.
    hes in mass too wink wink.
  6. #6 Re: 284 fail. 4t80e possibly inc.
    He's right in Indian Orchard at the edge of Springfield.
  7. #7 Re: 284 fail. 4t80e possibly inc.
    gardner,mass
    More info in my build thread. Basicly machine shop ****ed me with flywheel, clutch hit bellhousing, **** got warped, bye bye trans.
  8. #8 Re: 284 fail. 4t80e possibly inc.
    hangover park IL
    you might as well just go tube chassis and rear wheel drive
    ~James~ Psychotic Gearhead
  9. #9 Re: 284 fail. 4t80e possibly inc.
    gardner,mass
    Quote Originally Posted by Turbocharged400sbc View Post
    ^lols^
    I wish. 4t80e swap cant be that involved can it?
  10. #10 Re: 284 fail. 4t80e possibly inc.
    hangover park IL
    it's been described as being painfull on a level similar to a man giving birth
  11. #11 Re: 284 fail. 4t80e possibly inc.
    Kansas City
    I heard it was a pain but that sounds real bad lol
  12. #12 Re: 284 fail. 4t80e possibly inc.
    hangover park IL
    somewhere I actually have measurements for the aluminum subframe in the Regal for changing the design of my solid aluminum 80e mounts I did for the 442
  13. #13 Re: 284 fail. 4t80e possibly inc.
    Kansas City
    I thought about the 80 swap myself but I was quickly talked out of it.
  14. #14 Re: 284 fail. 4t80e possibly inc.
    hangover park IL
  15. #15 Re: 284 fail. 4t80e possibly inc.
    GTP Level Member 231FUN's Avatar
    Dec 2011
    Ontario,Canada
    I hate to hijack a thread but it's 4T80 related
    In the last few days I've seen a couple cheap cars that have the Northstar and 4T80 engine trans, one being a Bonneville GXP and the other an Olds Aurora.
    How involved would a 3800 swap in theese cars be if possible?
  16. #16 Re: 284 fail. 4t80e possibly inc.
    Howell, NJ
    There was a member on here with a 3800 Aurora, I think his name is max. Bill knows him.
  17. #17 Re: 284 fail. 4t80e possibly inc.
    Dec 2011
    Ontario,Canada
    Quote Originally Posted by Jomamma View Post
    I know the car too but that wasn't my point, it's a 3800/4t65 Aurora I believe.
    I was talking about Aurora and Bonne gxp's that came stock with the Northstar engine and 4t80 trans combo, just curious if anyone has 3800 swapped one of them and kept the 4t80 with a swapped in 3800?
  18. #18 Re: 284 fail. 4t80e possibly inc.
    Arizona
    Northstar only come with 4t80e motors in fwd. Refer to turbocharged400sbc above. Just Google him and the build he did will pop up or you can look up Jeff boneVille twincharge 4t80e 3800.
    But yes 3800 will bolt up same as any gm metric bell housing bolt pattern motor
  19. #19 Re: 284 fail. 4t80e possibly inc.
    Dec 2011
    Ontario,Canada
    I didn't think my post was that difficult to understand.
    I know FWD northstar cars came with the 4t80.
    Pontiac Jeffs car was a 96 Bonneville...didn't come with a 4T80
    Turbocharged400sbc's build and Dave at TEP's 4t80 build are also both 4t80 swaps into cars that did not have them in the first place.
    I was looking for an example of some one who did a 3800 swap on a Bonne gxp with the Nothstar/4T80 and pulled the Northstar and shoved a 3.8 in it's place.
  20. #20 Re: 284 fail. 4t80e possibly inc.
    hangover park IL
    Way too pricey of a car.
  1. Replies: 83
    Last Post: 10-05-2014, 12:36 AM
  2. Twin Engine GTP new 4t80E trans setup testing at dragstrip
    By TwinV6GTP in forum Track Sessions and Kills
    Last Post: 08-17-2014, 07:27 PM
  3. 4t80E trans swap
    By TwinV6GTP in forum 1994-2011 4 speed Automatic (4T80E)
    Last Post: 08-14-2014, 08:06 PM
  4. 4t80e forum
    By turbocharged406sbc in forum Forum Bugs/Suggestions
    Last Post: 08-13-2014, 09:05 AM
  5. 4t80e swap into grandprix
    By coreysGTP in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 12-28-2012, 09:20 AM
