Thread: Overdrive Issue
Results 1 to 19 of 19
  1. #1 Overdrive Issue
    Nov 2016
    Oklahoma
    Hello folks,
    It has been a while since I have posted anything on here, but I am in desperate need of some help today. Let me give you the car specs first:
    1995 Pontiac Grand Prix
    3.1 Liter V6
    Miles: 225,000
    Transmission: (salvage yard) 4T80E
    The issue I am having is that my mother had a mechanic put the transmission in the car about eight months ago or so. My mother said that the car was running great, but the gas mileage did not seem to be where it needed to be. I actually took the car to work with me, which was two hours or so from where she lives, so that I could take a look at it in my friend's shop. I noticed on the way up that it was not going into overdrive. The transmission does not slip, and it pulls strong. I can do a manual shift through: first, second, and third fine. When I go to drive the RPMS never change. It doesn't even try to go into overdrive, almost like it's not even there. I have found a two wire plug on top of the motor that was left loose over by the alternator. I don't remember the exact color of the wires, I remember one was yellow. The plug length is probably just over a foot long, and the end is red in color. I have looked at several wiring diagrams trying to find where this creature goes, and what it is, but no luck. To me it's almost like lockup is not getting the 12v it needs to engage.
    Here are some fluid specs on the tranny:
    Color: Light red
    Smell: Not burnt
    Level: full at idle
    Can someone point me on what I need to do to start diagnosing the issue. I really think the transmission is okay. It pulls really strong, and doesn't slip.
    Thanks,
    littlekatfish2003
  2. #2 Re: Overdrive Issue
    GTP Level Member
    Oct 2014
    Rebuild tranny. You lost the splines on the 4th gear shaft. Or just drive it in 3rd.
  3. #3 Re: Overdrive Issue
    Nov 2016
    Oklahoma
    Is there a diag that I can do to see if it's the 4th gear splines, before I go through the trouble of pulling the tranny and going through a rebuild?
  4. #4 Re: Overdrive Issue
    Mar 2014
    Tucson
    Quote Originally Posted by littlekatfish2003 View Post
    Assuming this is actually a 4t60e, you kind of already did...
    Last edited by BrandonHall10; 01-24-2017 at 01:08 PM. Reason: I managed to typo a correction
  5. #5 Re: Overdrive Issue
    Mar 2014
    Tucson
    It can be fixed without fully removing the trans. It's a pain, but it's doable.
    Here's what you'll likely find
  6. #6 Re: Overdrive Issue
    Nov 2016
    Oklahoma
    Brandon,
    Did you have to unbutton the cradle a bit to get to spline? I have never been in one of these transaxles before. I have been in several transmissions, never a transaxle. Think you would have time to give me a run down?
    Thanks,
    littlekatfish2003
  7. #7 Re: Overdrive Issue
    Mar 2014
    Tucson
    Already been done, and by a far better wrench than myself.
    http://www.grandprixforums.net/threa...ht=clutch+easy
  8. #8 Re: Overdrive Issue
    Nov 2016
    Oklahoma
    Thank you
  9. #9 Re: Overdrive Issue
    Hey guys...4t60 wasn't know for the 4th spline issue.
  10. #10 Re: Overdrive Issue
    Mar 2014
    Tucson
    Whoops. Missed that part.
  11. #11 Re: Overdrive Issue
    FWiw I haven't really heard much about 60s losing fourth that I can think of
  12. #12 Re: Overdrive Issue
    GTP Level Member
    Oct 2014
    Yes. He does describe losing the 4th spline's by his symptoms.
  13. #13 Re: Overdrive Issue
    Not reall from what I see. I see that it doesn't go to 4th. I don't have the 60 solenoid pattern, could be a solenoid etc. Having a transfer shop diagnosis might be good in my eyes
  14. #14 Re: Overdrive Issue
    Nov 2016
    Oklahoma
    When I will get home today, I will take a picture of the plug and the color of the wires that I have located by the alternator that is currently loose, which I have no idea what it does, or where it belongs. I have looked on several wiring diagrams. I cannot find what it is or where it goes. I'm not to sure that it may have something to do with the lockup getting the 12v it needs to engage. I have verified that it is a 4T60E. The 4T80 was not available in this car yet at the time it was produced. When I cruise down the highway in it, it drives really well. I have: first, second, and third. It never even attempts to go into 4th gear. The RMPS stay at about three grand doing 65, they never drop and come back up like it is slipping in and out of overdrive. It never attempts to go into it in the first place. Any other thoughts or ideas? Really looking on where to start. The car is OBD 1 and isn't even throwing a code for it. No check engine light or anything.
  15. #15 Re: Overdrive Issue
    I had made a set of connectors and switches to test the 4t65. You could do the same.. if you commandon't 4th and get nothing I'd checkeep the soleniod... with a 600 though... I'm no expert. I fd up everything 4t65
  16. #16 Re: Overdrive Issue
    60 is what I meant
  17. #17 Re: Overdrive Issue
    Nov 2016
    Oklahoma
    Okay I got my friend to hook his scanner up to the car this last weekend. I don't remember the exact code, but there was a tranny code. He said that the computer doesn't know what gear the car is actually in. He said it is only reading first and second according to his scanner. He said to replace the range sensor on the tranny and it should fix it. I have been doing some research on this range sensor, I am not sure if it is actually in the tranny, or an external part. I found the neutral safety switch, which is the switch the shifting cable runs into I believe. Do you all have any: thoughts, questions, or ideas? If someone knows where this sensor is, please point me where I need to dive-in to get to it. I also need help finding the part. I called O'reilly's, they couldn't even order the part. Any help would be great.
    Thanks,
    littlekatfish2003
  18. #18 Re: Overdrive Issue
    on the 4t65 is on the pass side of the tranny in the diff housing. where id look to start. typically its a bolt through a tab then pull it out, its sealed with a o ring.
  19. #19 Re: Overdrive Issue
    Donating Users moddman's Avatar
    Midwest
    Check your pass. side wire harness going near the front fender wall. If 1995 are the same as 98-02 those wires get cut up near there and they feed the trans. range switch. A quick clue is that the reverse lights dont come on if the harness is jacked.
    3.4" ZZP MPS Pull
    ey,ZZP Coupler,NGK PLUGS,L67 Coils,INTENSE 1.8 RR, Custom PCM Tune, ZZP Stage 2 IC, 180* T-Stat, 42LB RE-FLWD Inj.
  1. Overdrive at 38 MPH
    By Chadgervais in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-16-2013, 05:58 AM
  2. 99 3.1L no overdrive, please help.
    By nickykreb in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-05-2013, 08:37 AM
  3. trans issue.....no 1st or overdrive
    By glhtomni in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-28-2011, 08:48 PM
  4. overdrive
    By BOOSTED GP in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-09-2011, 12:03 PM
  5. On-and-off overdrive...
    By Hogrydr in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 10-22-2010, 11:32 PM
