Thread: need your help badly trannyman
Results 1 to 16 of 16
  1. #1 Re: need your help badly trannyman
    SE Level Member Zainoman's Avatar
    Tulsa, Oklahoma
    well if its something to do with my transmission itself wouldnt i have the symptoms no matter what i did? makes no sense that the transmission itself is working perfectly now if there is something wrong with it. its not just going to go away unless it was the pcm. (i did do the big three not even two days ago and had to reset it. which im willing to bet since ive gone wot so many times it didnt give the pcm time to relearn the correct shift points....) please correct me if im wrong.
    All that work and all those mods mean nothing if your ride isnt clean
  2. #2 Re: need your help badly trannyman
    Barksdale AFB, LA
    The PCM adapts to things going on in the tranny. If it detects its slipping it will eventually command higher line pressure to combat the problem, which results in harder shifts.
    Resetting the PCM cleared this so the tranny is learning everything again. If the slippage is still there then the tranny will take time to realize it and eventually command higher pressure again. All you did was clear the learned parameters, nothing more. It's relearning.
    2009 Subaru Impreza WRX STI
  3. #3 Re: need your help badly trannyman
    Tulsa, Oklahoma
    so is that a bad thing and my problem is going to come back??
  4. #4 Re: need your help badly trannyman
    Barksdale AFB, LA
    Quote Originally Posted by Zainoman View Post
    It may it may not. That's why everyone was saying we'll have to wait and see.
  1. Trannyman...need your advice...
    By VerzGTP in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-30-2008, 07:52 AM
  2. hey trannyman!!!!
    By yokosgs in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-06-2008, 11:15 PM
  3. So who here thinks Trannyman should change his profile?
    By Zef_66 in forum Off Topic Discussion
    Last Post: 02-26-2008, 09:39 PM
  4. Trannyman, please check your email. I blew up :(
    By JCGT in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-17-2008, 03:35 PM
