Thread: How to perform Security relearn on 04+ when changing PCM
Results 1 to 1 of 1
  1. #1 How to perform Security relearn on 04+ when changing PCM
    GXP Level Member
    Mar 2015
    Tomball
    Start by disconnecting battery negative.
    Remove old PCM and install new PCM.
    Reconnect battery.
    If you have an old or weak battery connect a charger, this is a 45 minute process. If you screw up you are going to have to do it again.
    On 05' up at least setting the emergency brake does not disable the lights so just turn them off if you need to.
    Turn the key to the start position and release it to the run position, car will not start and DIC will say "Starting disabled due to theft system" leave key in the run position for 10 minutes.
    Turn key off for 10 seconds, then to start and release. Wait 10 minutes.
    After the Third time turn the key off and then start the car, if done correctly the car will start, the DIC may say Security relearn NOT done or finished when you turn the ignition on, but go to the start position and it will start.
    I let the engine run for several minutes as it finds it legs and settles into a proper idle.
    Now go drive,
    Jeff
  1. tb relearn
    By dsmuts in forum 04+ Specifics
    Last Post: 02-28-2014, 10:21 AM
  2. Need help with Security relearn and motor mounts
    By sasquatch094 in forum General Tech Discussion
    Last Post: 08-07-2013, 10:11 AM
  3. Replies: 1
    Last Post: 07-08-2013, 04:16 PM
  4. How do you perform a crank case relearn?
    By GOTIT4CHEAP16 in forum PCM Tuning
    Last Post: 08-16-2010, 06:28 AM
  5. Security Relearn
    By 04CompG in forum General Tech Discussion
    Last Post: 09-12-2008, 05:25 PM
