Do you have a volt meter? If you do, stick the probes in the connector and see what you get. Should be around 12V. Also check the connector and see if it's not backwards. The connectors can easily be mistaken if you just connect them by how it LOOKS like it will go (ask me how I know haha) Make sure the ground from the plug matches with ground on the connector.
