Thread: 08 pcm tune
Results 1 to 6 of 6
  1. #1 08 pcm tune
    Jan 2015
    minnesota
    So i was told you cant tune an 08 grand prix but i was wondering if theres anyway able to tune it?
  2. #2 Re: 08 pcm tune
    Currently there is nothing on the market that can tune a base 08 grand prix, only the GXP model with the V8 can be tuned as the pcm is different.
    It has a year only computer, when they switched to a can-bus style systems on the cars. But soon after the grand prixs were cut and pontiac was pretty much done altogether. If pontiac continued to be made there would have likely been a better pursuit at making it possible to tune them.
    You also can't switch it out for a 07 or order pcm because of the can-bus.
  3. #3 Re: 08 pcm tune
    Jan 2015
    minnesota
    Dang that sucks but if i put er rocker, hv3 insert an a 2.5 downpipe do i need a tune? Or can i run it with out one
  4. #4 Re: 08 pcm tune
    You wouldnt "need" a tune for those but I'd be careful of what converter is in that downpipe.
    It might flow to well for the cars rear o2 sensor and cause the check engine light to come on. If you could cut the stock cat out and weld it in that pipe you'd be golden still.
  5. #5 Re: 08 pcm tune
    Aug 2013
    McDonald PA
    It will flow to much and will set an ses you'll need a fouler/spacer from ebay
  6. #6 Re: 08 pcm tune
    Jan 2015
    minnesota
    Alright thanks guys for the help
  1. e85 Dyno Tune at Dyno Tune Motorsports - Video
    By tms8582 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-26-2013, 07:57 AM
  2. tune vs no tune. safe?
    By hollas13 in forum General Grand Prix Discussion
    Last Post: 07-09-2013, 07:54 AM
  3. help!14.6@ my tune, 14.4@ stock tune w/genV+
    By Brooks in forum PCM Tuning
    Last Post: 08-16-2010, 06:16 AM
  4. How to get a tune
    By 06grandprix93 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-24-2010, 09:01 PM
  5. Tune up
    By JB381 in forum Engine
    Last Post: 02-22-2010, 06:34 PM
