Thread: TPMS 128 psi?
Results 1 to 6 of 6
  1. #1 TPMS 128 psi?
    SWPA
    I went through to check the tire pressure on the DIC when the weather started getting colder and noticed the left front reads 128 psi. Is this a faulty sensor or does it just need reset?
    BTW I did search, but the search here sucks because it won't search for 3 letter/number words.
  2. #2 Re: TPMS 128 psi?
    Hard to say, the sensor might have died.
    The small TPMS scanner tool at my work can test all of them and reset them to the car. So if it reads the same as whats on the dash then I would have it replaced.
  3. #3 Re: TPMS 128 psi?
    GTP Level Member gpse2000's Avatar
    Apr 2011
    Fargo
    Did you try resetting it?? Not sure how 07+ are but on my 06 there is a reset option in the dic. I don't have the individual readings at all four tires like 07+ do tho so could be different
    2002 Denali Airaid MIT, Tint, 121k GARNET RED
    2006 GT S/C CAI, Plog, 3" DP, Flipped Mounts, DR STBs, SPO Grilles, SPO TIPS, Tint, Inlays, 120k BLEEN FOR SALE
    2000 SE 3.8 intake, dic swap, debadged, flipped mounts, rust mod 140k SILVERMIST SOLD
  4. #4 Re: TPMS 128 psi?
    SWPA
    I haven't tried a reset yet. The reset on mine is where you put the key to the on position, hold lock and unlock on the remote, then go around each tire letting air out until the car honks.
    I'm going to try that and see if it fixes it. If not, then I will just deal with it until I need tires.
  5. #5 Re: TPMS 128 psi?
    Something to consider.. .battery life
    http://www.tpmsdirect.com/OE_TPMS_Li...ancy_a/283.htm
  6. #6 Re: TPMS 128 psi?
    SWPA
    Hmm. Well I will probably be due for tires come spring if that's the case. May just buy 3 and replace the the older ones. I replaced one two years ago. It should be okay and last long enough until I get rid of the car.
  1. TPMS...I know,I know.
    By MyteeMyk in forum Tires & Wheels
    Last Post: 05-31-2012, 03:55 PM
  2. Tpms ?
    By FriboRage in forum General Grand Prix Discussion
    Last Post: 03-24-2012, 12:31 AM
  3. anyone abandon TPMS?
    By OmegaRed in forum Tires & Wheels
    Last Post: 02-17-2011, 10:05 PM
  4. Tpms,....wft?!?!
    By Morris 04 GTP in forum General Tech Discussion
    Last Post: 07-29-2010, 06:40 AM
  5. TPMS???
    By xbnb1978x in forum Tires & Wheels
    Last Post: 08-05-2008, 11:53 PM
