Thread: Upgrading to steering wheel controls
Results 1 to 20 of 36
  1. #1 Re: Upgrading to steering wheel controls
    all that mumbo jumbo talk is how to center the clock spring, the rest is just like i said pretty much.
    dont sweat it. i see no need to change the column.
    if you get your clock spring at the junk yard make sure the wheels are straight if at all possible then take the clock spring out. if not you need to center it. its not hard, i did it to mine.
    the simple way to explain it is.
    theres a button on it, push it in the center will now spin, slowly turn it one way till it stops. now count how many full turns it takes to get to the other side. mine was 7 iirc. turned it back 3 1/2 turns, done. put it on the shaft. be genital with it, and try to force it any further then it wants to go or you will break it.
  2. #2 Re: Upgrading to steering wheel controls
    London Ont, Canada
    So your saying if it ISNT straight when i take it out i can center it myself by doing what you said about the revolutions?
    But if i can get it outta the car centered, i just need to pop it into mine and im good to go?
  3. #3 Re: Upgrading to steering wheel controls
    correct.
    most JY cars have no keys and the wheels are locked, makes things tough sometimes.
    i was kinda surprised mine even worked. it was rolling around in my trunk for months till i broke it all apart to use parts off it.
    so i swapped the bag and wheel, first time it was off.
    then did the clock spring #2
    then did the directional multi switch #3
  1. upgrading steering wheel
    By canadian2000gtp in forum Visual/Body Modifications
    Last Post: 05-23-2012, 10:42 PM
  2. steering wheel controls
    By macey43 in forum Audio, Security & Visual Electronics
    Last Post: 08-12-2010, 07:54 PM
  3. Steering Wheel Controls....
    By RedGTDT in forum Audio, Security & Visual Electronics
    Last Post: 07-18-2010, 09:59 PM
  4. steering wheel controls?
    By CrazyCanuck in forum Audio, Security & Visual Electronics
    Last Post: 02-16-2009, 12:42 PM
  5. steering wheel controls
    By 52 picup in forum General Tech Discussion
    Last Post: 10-22-2008, 10:44 PM
