Thread: Traction control not working!
Results 1 to 5 of 5
  1. #1 Traction control not working!
    GT Level Member des19's Avatar
    May 2011
    Ontario
    Hi, I am wondering if any of you have had this in your gps.
    I was driving about a month ago really low on gas and the rpm gauge was not working at all was at constant 0, but everything else was working. I filled up turned the car off and on and it went back to normal. Shortly after I realized my tractiion control button was not working at all. I gave up.
    Later on in the week I noticed it would work if you hit it a few times,
    Now a month later it will not work at all no matter how maany times i press it. Anyone know whats going on??
  2. #2 Re: Traction control not working!
    St. Louis
    Tach dropping to 0 while still running almost sounds like a crank position sensor starting to go. If so, then soon your car may start just randomly dying on you until it just won't fire up anymore once the sensor is shot.
    Barring that could be some corrosion on the battery cables. Remove them both, clean the batt. and the cable ends, put a little dielectric grease on them and reattach making sure they are tight. I've seen loose/dirty cables cause this too.
  3. #3 Re: Traction control not working!
    May 2011
    Ontario
    It only did it once very quickly and worked grat after turning the car off and on...as for the tc button i will take it off nd clean it and re install see if that helps.
    SE Level Member kyrebel's Avatar
    Dec 2010
    Louisville, Kentucky, United States
    Ive had the same thing happen a few times but only after washin the car i started blowing off the electrical connectors with an air gun and havent had it happen since
    Sent from my SAMSUNG-SGH-I997 using Tapatalk 2
  5. #5 Re: Traction control not working!
    Donating User Odi's Avatar
    Chicago South Suburbs
    ^^ this. clean the connectors first.
  1. Traction control, ABS and Cruise control dont work
    By Adamcc91 in forum Brakes/Suspension/Chassis
    Last Post: 02-04-2011, 05:07 PM
  2. Traction control, stability control , abs brakes warnings
    By warren13 in forum General Tech Discussion
    Last Post: 09-18-2010, 06:26 PM
  3. traction control?
    By bensett004 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 09-27-2009, 08:56 PM
  4. Traction Control
    By tynev7 in forum General Tech Discussion
    Last Post: 08-18-2009, 10:55 PM
  5. ABS/Traction control
    By holsports in forum General Tech Discussion
    Last Post: 03-22-2009, 11:32 AM
