Thread: gurgle / running liquid sound when accelerating
Results 1 to 12 of 12
  1. #1 gurgle / running liquid sound when accelerating
    El Paso, TX
    So for a while now when I accelrate especially in 1st and 2nd gear I hear noise from somewhere in the console or like under the shifter. Its hard to describe like gurgling or like water sloshing or running through something down there. Its very weird I thought nothing of it until recently when it became louder, before i would hear it once in a while and now its really present. Everything else is normal besides the terrible transmission. thanks
  2. #2 Re: gurgle / running liquid sound when accelerating
    El Paso, TX
    oh low coolant? found a related post but the dic doesnt tell me that its low so yeah
  3. #3 Re: gurgle / running liquid sound when accelerating
    MO
    Low coolant or an air bubble in the line
    <brandonl2000> LMAO D!!
  4. #4 Re: gurgle / running liquid sound when accelerating
    GTP Level Member lambokit's Avatar
    Apr 2009
    Radford, Virginia
    Yes, sounds like low coolant OR air in the system. More than likely it's air in the system.
    Lambokit to be built!!!!!
  5. #5 Re: gurgle / running liquid sound when accelerating
    El Paso, TX
    how would i go about bleeding it? im one of those let the dealership do it ppl but not anymore
  6. #6 Re: gurgle / running liquid sound when accelerating
    GT Level Member Jakescoots's Avatar
    Spring Lake, Mi
    there is a valve on top of where the t-stat is, just open it and let it run until the bubble is gone
    Does removing the spare count as weight reduction?
    Badges on a car are just advertisements....Everyone already knows what it is. And if they dont, its a mystery. People like mysteries.
  7. #7 Re: gurgle / running liquid sound when accelerating
    Jul 2008
    Tampa, FL
    iirc, it should be like an 8mm goldish looking nut. get it running and loosen it until you see the bubbles coming out. then just tighten it back down...
  8. #8 Re: gurgle / running liquid sound when accelerating
    London Ont, Canada
    you probably have the same issue as I do.. Air in the heatercore.. from the posts i was getting (http://www.grandprixforums.net/sloshing-wtf-46237.html) jacking up the front end and bleeding it while raised should help to get the air out.. thats because the heater core sits so low compared to the rad. I havnt tried this yet myself but it sounds legit.
  9. #9 Re: gurgle / running liquid sound when accelerating
    Donating Users Durk Diggler's Avatar
    Pittsburgh
    Follow my instructions in that thread. You need to bleed it out the old school way.
    Air in your heater core is not good. The dexcool will eventually react to the air and turn to sludge and clog it and it will need replaced after coolant leaks into your car.
    Durkz 04 Silver GT2
    DHP'd, Comp G'd, looking for more speed
    http://www.grandprixforums.net/zzps-new-website-2-53834.html#post678234
  10. #10 Re: gurgle / running liquid sound when accelerating
    GT Level Member tylerbinski's Avatar
    Canada
    THanks - having the same issue - going to raise front and fill/bleed.
    Cheers
    '04 BLK GP - .. Turbo :P
    GTP SIC - '02GTP | XP Cam | Intercooled Turbo Kit | Cutout....Fire mod 9/11
    GTPSIC '02 | Twin charge, XP cam et
  11. #11 Re: gurgle / running liquid sound when accelerating
    Akron, Ohio
    I had this issue and bleeding the system did not work. Then the heater quit working. I looked on youtube how to flush the heater core. It takes about 10 minutes to do and solved the problem.
  12. #12 Re: gurgle / running liquid sound when accelerating
    GT Level Member thegipper's Avatar
    grafton, wi
    Its actually a 7mm nut. Start the car up and let it fully warm up. Once its warmed up, open the bleeder screw on top of the thermostat housing. If their is air in the system it should come out. Once coolant starts coming out, close it back up.
    Be sure to check your coolant level and make sure its full.
    02 GT - HV3, 3800 Perf. Tuned, Plog, ER rockers, DP w/Magnaflow, CAI, 180* stat, Plugs/Wires, Poly Uppers, Driver mod.....
  1. Gray liquid in coolant reservoir on 97 gtp
    By SteveCZ28 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-29-2010, 10:47 PM
  2. New Liquid Metal Rims and Tires, and other mods..
    By ddrum in forum Visual/Body Modifications
    Last Post: 10-02-2010, 08:25 PM
  3. liquid gasket used for sc and lim
    By funky4stringed in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-14-2010, 11:07 PM
  4. coolant gurgle sound under dash???
    By symonqg in forum Introductions/Noob Questions
    Last Post: 03-11-2010, 06:21 PM
  5. Sloshing sound while accelerating
    By Quicksilver_GP in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-19-2009, 07:45 PM
