Thread: 04+ HUD Install
Page 2 of 2 FirstFirst 12
Results 21 to 36 of 36
  1. #21 Re: 04+ HUD Install
    Sep 2015
    Houston TX
    Niiiice. Let's see it 🌅
  2. #22 Re: 04+ HUD Install
    Aug 2015
    Austin, TX
    Well its been a long process but today I got my dash piece and the HUD projector should be here tonight! Think I'm ready with everything. Wiring harness made and installed (tapped into IP), switch and new console installed a few months ago. Ready to cut and install! I think tomorrow is gonna be the day though... not enough time left tonight to get to it. I have nav, so figuring out how to get the nav signal from the unit to the BCM was... um... difficult. I guess ill find out if I got it right when everything is installed.
    Question/concern that I've come across, don't know why my switch is not illuminated. Its plugged in to the IP, but obviously I haven't installed the HUD yet. Hard to say if it working. Anyone else have a switch installed that didn't light until the HUD was in?
  3. #23 Re: 04+ HUD Install
    Aug 2015
    Austin, TX
    Success! Got the HUD installed today. A few issues though... #1 my switch does not illuminate, but it does work otherwise, so I'll replace it at some point in time. No biggie. #2 is that I am not getting signal from my nav unit/radio to the HUD. Thought I had the wiring from the nav to the bcm correct, but evidently not. Going to look into this further and will report back with the solution so if anyone else does this install they'll know how to make it work properly.
  4. #24 Re: 04+ HUD Install
    GTX Level Member Travisgt2's Avatar
    Jan 2013
    leavenworth ks
    I connected to the grey wire that goes to the instrument panel that's what I tapped into
    Sent from my SM-S820L using Tapatalk
    04 GT2: 180 t-stat, cold air intake, reptile tune, plog, hv3, gt1 cam, 90#springs, new push rods, new lifters, port polished heads, lim, uim and tb, 06 Impala brakes and steel brake lines. Cosmetic: black roof rails, under glow, Pontiac ground light, blue hud dic radio controls and cluster. To come custom hood.
  5. #25 Re: 04+ HUD Install
    Jan 2013
    leavenworth ks
    Oh sorry you said nav radio stuff i don't know anything about that
  6. #26 Re: 04+ HUD Install
    Aug 2015
    Austin, TX
    Quote Originally Posted by Very Lost View Post
    Yeah, to be clear, there is a way to get the signal from the nav to the bcm, but I'm not sure how to do that. I know the bcm is passing the DIC signal to the HUD, so its not a bcm issue. Some connection needs to be made so that the nav/audio unit gets the proper signal for turn-by-turn directions and radio info to the HUD. There will be a connection from the XM harness on the nav unit, and I assumed it would go to the vehicle speed signal wire connection, but there are 4 wires going into the bcm that are the same color (green) as the vehicle speed signal input wire. I may have got the wrong one. I'll figure it out at some point.
  7. #27 Re: 04+ HUD Install
    GTP Level Member Kaiser Pontiac's Avatar
    Jun 2015
    Land of 10,000 Salted Roads and Rusty Cars.
    Curious, did you guys all just get a different console, or just tap a hole in your existing one for the HUD switch?
    06 LaCrosse 57-79k sold;99 4dr GTP 134-138k sold;98 2dr GTP 183k parted;98 Regal 166-184k;04 GT2 204-206k sold;04 GTP 170-175k sold;09.5 G8 GT Sport 145k;09 G8 78-84k+;08 Prix 164k sold;06 Prix 168k sold;02 Regal 92k;09 G8 103k parted;04 GTP SpEd 139k parted;04 GTP 205k;'09 G8 105k parted;06 Prix 230k​;04 CompG 138k
  8. #28 Re: 04+ HUD Install
    Jan 2013
    leavenworth ks
    Drilled hole above ash tray and that's where switch is at on mine.
  9. #29 Re: 04+ HUD Install
    Jun 2015
    Ah, okay. I prefer the spot where your's is at, so I might just do that.
    "I was lucky enough to obtain a wiring harness for the HUD and adjustment switch, so fortunately it was all just plug n' play after I wired everything together correctly."
    So..., how much should I have the guy I'm buying this from hack into his wiring harness for me?
  10. #30 Re: 04+ HUD Install
    Jan 2013
    leavenworth ks
    I pm'ed you
  11. #31 Re: 04+ HUD Install
    Jan 2013
    leavenworth ks
    As much wire as possibly for the part that plugs into the hud and then the entire center consul harness
  12. #32 Re: 04+ HUD Install
    Jun 2015
    Yup, got your PM.
    Okay...., thanks.
  13. #33 Re: 04+ HUD Install
    Aug 2015
    Austin, TX
    Quote Originally Posted by Kaiser Pontiac View Post
    I bought a console off eBay that had the switch and switch-to-IP wiring already in it. I wanted to replace my console anyway because the prior owner had gotten cig burns around the ashtray and it bothered the **** out of me. It was like $75 and the console I bought was like brand new. So it all kinda worked out.
    You have your wiring connectors? If not I have a HUD connector and an IP connector I pulled out of a car at a junkyard that you're more than welcome to. Pulled 2 sets because its nice to have extra in case I ****ed something up, but now I don't need the extra set.
  14. #34 Re: 04+ HUD Install
    Aug 2015
    Austin, TX
    Figured I'd give a wrap up on my situation as it is now solved. Background is that my GP is an 05 GT that had OEM nav from the factory but no HUD. I installed the HUD but wasn't getting radio and nav signal to display on the HUD. After a lot of failed attempts at solving it, I went to the dealer. Asked them to program the RPO for the HUD (UV6) so the PCM would see the signal from the radio and send it to the HUD. They pushed back and said they wouldn't do it because according to them the 05 doesn't get nav directions on the HUD, which I knew was bull**** because it states it in the service manual but it doesn't say how to program it. So I had them check the build sheet to make sure the nav was factory installed, and it was. That means the signal is there but the PCM doesn't know to send it to the HUD because it doesn't know the HUD is there. Went to another dealership, asked them to reprogram, they did, and it worked.
    So, if you have nav and add HUD, you have to get a reprogram to get HUD online and accepting the nav signal to display turn by turn directions and radio station data . And vice versa, if you have HUD and decide to add factory nav, you'll have to get a reprogram to get the nav online too.
  15. #35 Re: 04+ HUD Install
    Jan 2013
    leavenworth ks
    Good information to have. Any one have a spare five button dic?
  16. #36 Re: 04+ HUD Install
    Jun 2015
    Check car-part.com? There's a few for $35 in Kansas City.
  1. cam install
    By 2001goldGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-01-2011, 02:18 PM
  2. What do I need to install a cam?
    By BillBoost37 in forum How To Write-Ups/Tech Tips
    Last Post: 07-28-2011, 12:05 AM
  3. 04 HUD and or DIC install?
    By joshuaandrew92 in forum Audio, Security & Visual Electronics
    Last Post: 07-17-2011, 11:54 PM
  4. Z7 Install help
    By ARFF22 in forum Turbo
    Last Post: 02-01-2011, 01:35 AM
  5. Do I need a cam kit to install a VS cam
    By ncccgolf5 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-02-2009, 02:51 AM
