Thread: Heater Core Replacement
Results 1 to 20 of 59
  1. #1 Re: Heater Core Replacement
    May 2016
    Lincoln, Nebr
    I installed an Adv'd Auto HC (PN 399329), it looked identical. Ended up using 3/8" weather seal from Lowes. A guy in a GM forum said he tested it in an oven at 350 and it was fine (see link).
    Finished this project couple days ago. Not the hardest thing I've done, but definitely the most inconvenient. I think the plastic donuts were by far the worst for me. I also spent a lot of time trying to get the heater hose clamps off the HC near the firewall - they were just in and awkward spot with the pliers. Replaced the heater hoses as well, cuz why not, and I used standard hose clamps to reattach to the HC and tensioner fittings. Two flushes with distilled H2O (in order to remove bars leaks I had to use to get home 200 miles), refill, burp, and reassemble.
    I didn't reuse the little screws I took out. I just used the 3/4" #6 sheet metal screws for the whole reattachment. I think spazzz referenced these earlier in the thread. They went in fine, no pre-drilling. I did use a drill with a right angle attachment to take some labor out of it.
    I'm glad this thread existed, because it truly did help me out, there's not videos on GP's - so thank you to everyone.
    http://www.gmforum.com/general-gm-ch...al-kit-308307/
    This also visually helped me a little bit before I got started - https://www.youtube.com/watch?v=_cOYV_dy47A
  2. #2 Re: Heater Core Replacement
    GTX Level Member cheatah faheatah's Avatar
    May 2016
    Rouge Island
    In the future, there is a spring hose clamp removal tool. Should be part of Adv'd Auto Loan-A-Tool dealio..... One end kinda looks like a bicycle hand brake w/cable going down to a small "caliper" looking end.
    For the record : I am NOT a naked meth-head who shoves rocks up my butt.
  3. #3 Re: Heater Core Replacement
    Nov 2015
    Chicagoland
    Does anyone have photos of the heater core cover and the HVAC cover in place? I've got everything replaced but I may have offset the covers, I'm not sure. It doesn't look correct. I'd only use the heater core cover but that seems to severely limit the amount of heat thrown on the windshield or through the dash vents.
    Good floor heat but only cold air through the dash and defrost. Is my problem something else?
  4. #4 Re: Heater Core Replacement
    GTP Level Member CHI2000GTP's Avatar
    Dec 2015
    Chicago, IL
    Quote Originally Posted by PizzaAndDoughnuts View Post
    ^^ likely the blend door. Just finished installing a heater core into my 2000 GTP. I have a pic of the heater core cover. Not sure GP you have though.
    2000 GTP 4DR - Stock
    243,000 miles
    CHICAGO, IL
    My Car: http://www.grandprixforums.com/members-rides/103740-lukes-gtp.html#post1443981
  5. #5 Re: Heater Core Replacement
    Dec 2014
    DTW
    Quote Originally Posted by CHI2000GTP View Post
    HINT: This thread is in the 2004+ specifics part of the forum. Your cover(s) look a lot different.
    Jeff
  1. Heater Core Replacement 97-03
    By Jakescoots in forum How To Write-Ups/Tech Tips
    Last Post: 01-20-2022, 05:21 PM
  2. heater core
    By gtpinsc in forum General Tech Discussion
    Last Post: 04-01-2011, 12:29 PM
  3. heater core
    By PONTIACGTP05 in forum Introductions/Noob Questions
    Last Post: 04-08-2010, 10:24 PM
  4. Ze heater core
    By Spazztic2003 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-08-2009, 03:23 PM
  5. Heater core replacement....
    By m0ng00se in forum General Tech Discussion
    Last Post: 11-19-2008, 10:10 PM
