Thread: Heater Core Replacement
Page 3 of 3 FirstFirst 123
Results 41 to 57 of 57
  1. #41 Re: Heater Core Replacement
    Feb 2013
    37.295091, -121.930053
    Quote Originally Posted by idrivejunk View Post
    Mmm steak.
    you mean like this
    im a cookie again yay me
    please learn to forum better.
    ^^new favorite quote
  2. #42 Re: Heater Core Replacement
    Nov 2015
    Arizona
    Has anyone seen a walk through or video of the short-cut method to replacing the heater core? I have searched everywhere and can not find one.
    Thanks,
    Mike
  3. #43 Re: Heater Core Replacement
    GTP Level Member bonerjamz03's Avatar
    Apr 2009
    Upper Darby, PA
    Quote Originally Posted by mikedpp View Post
    Thanks,
    Mike
    Not sure if there is a short cut. It's pretty straightforward as is, remove center console, covers and seats (not necessary, but gives a ton more room to work) to gain access to heater core. Install new heater core, reinstall all the other crap and you're done. It's not hard, just awkward and frustrating because you're working off your back at odd angles.
  4. #44 Re: Heater Core Replacement
    May 2016
    Lincoln, Nebr
    So is the center console in the way of reaching some of the screws or plastic rivets, so you absolutely have to take it out? or is this just a continence removal for maneuvering around?
    Also, do I need to pre-drill those #6 or #8 sheet metal screws or will they self-tap and not crack the plastic?
  5. #45 Re: Heater Core Replacement
    Dec 2014
    DTW
    You definitely need to take out the center shift console. It's four bolts and then you disconnect one wiring harness.
    The seats are optional (I didn't take mine out but I did get into some rather interesting poses/positions)
    Jeff
  6. #46 Re: Heater Core Replacement
    May 2016
    Lincoln, Nebr
    Wow...took those 2 covers off, that was some awkward work w/ the Air diverter and the core cover (idk what they're called). I found a drill and rotary tool were the best at removing those plastic donuts. I AM grateful for not having to remove the entire dash (like other cars), but seriously GM...use screws instead - think about the end user.
    I need a new foam seal for in front of the heater core, mine's all wet a messed up. Did you guys just use weatherstrip from HDepot, cuz I can't find a "Heater Core seal" or "heater core gasket" at a parts store. I'm just worried about the temperature of that thing against the generic household weatherstripping.
  7. #47 Re: Heater Core Replacement
    Dec 2014
    DTW
    My replacement AC Delco heater core came with the foam gasket.
    When I put mine back together I only re-installed the (inner) core cover because I wanted more
    heat on my feet rather than under my seats (no one sits in the back and my car was nearing it's
    life expectancy)
    Jeff
  8. #48 Re: Heater Core Replacement
    The center console most definitely doesn't need touched
  9. #49 Re: Heater Core Replacement
    May 2016
    Lincoln, Nebr
    I installed an Adv'd Auto HC (PN 399329), it looked identical. Ended up using 3/8" weather seal from Lowes. A guy in a GM forum said he tested it in an oven at 350 and it was fine (see link).
    Finished this project couple days ago. Not the hardest thing I've done, but definitely the most inconvenient. I think the plastic donuts were by far the worst for me. I also spent a lot of time trying to get the heater hose clamps off the HC near the firewall - they were just in and awkward spot with the pliers. Replaced the heater hoses as well, cuz why not, and I used standard hose clamps to reattach to the HC and tensioner fittings. Two flushes with distilled H2O (in order to remove bars leaks I had to use to get home 200 miles), refill, burp, and reassemble.
    I didn't reuse the little screws I took out. I just used the 3/4" #6 sheet metal screws for the whole reattachment. I think spazzz referenced these earlier in the thread. They went in fine, no pre-drilling. I did use a drill with a right angle attachment to take some labor out of it.
    I'm glad this thread existed, because it truly did help me out, there's not videos on GP's - so thank you to everyone.
    http://www.gmforum.com/general-gm-ch...al-kit-308307/
    This also visually helped me a little bit before I got started - https://www.youtube.com/watch?v=_cOYV_dy47A
  10. #50 Re: Heater Core Replacement
    GTX Level Member cheatah faheatah's Avatar
    May 2016
    Rouge Island
    In the future, there is a spring hose clamp removal tool. Should be part of Adv'd Auto Loan-A-Tool dealio..... One end kinda looks like a bicycle hand brake w/cable going down to a small "caliper" looking end.
    For the record : I am NOT a naked meth-head who shoves rocks up my butt.
  11. #51 Re: Heater Core Replacement
    Nov 2015
    Chicagoland
    Does anyone have photos of the heater core cover and the HVAC cover in place? I've got everything replaced but I may have offset the covers, I'm not sure. It doesn't look correct. I'd only use the heater core cover but that seems to severely limit the amount of heat thrown on the windshield or through the dash vents.
    Good floor heat but only cold air through the dash and defrost. Is my problem something else?
  12. #52 Re: Heater Core Replacement
    SWPA
    Possibly blend door.
  13. #53 Re: Heater Core Replacement
    GTP Level Member CHI2000GTP's Avatar
    Dec 2015
    Chicago, IL
    Quote Originally Posted by PizzaAndDoughnuts View Post
    ^^ likely the blend door. Just finished installing a heater core into my 2000 GTP. I have a pic of the heater core cover. Not sure GP you have though.
    2000 GTP 4DR - Stock
    243,000 miles
    CHICAGO, IL
    My Car: http://www.grandprixforums.com/members-rides/103740-lukes-gtp.html#post1443981
  14. #54 Re: Heater Core Replacement
    Dec 2014
    DTW
    Quote Originally Posted by CHI2000GTP View Post
    HINT: This thread is in the 2004+ specifics part of the forum. Your cover(s) look a lot different.
    Jeff
  15. #55 Re: Heater Core Replacement
    Jul 2016
    Michigan
    Thanks for the post.... looks like this has been up for quite a while.... it also looks like the pictures are now gone from the instructions. Do you still have those?
  16. #56 Re: Heater Core Replacement
    Nov 2012
    Madison
    If I remember correctly this link has the same pics/diagrams from the GM manual.
    http://www.justanswer.com/pontiac/5m...eatercore.html
    It's nice to have the locations of the screws which these point to. Depending on your physical size, you might be able to get at the core from both driver and passenger footwells without removing anything else.
    About the hardest part is sneaking the cowl out of the underseat duct work run, right below the radio.
    The 2 hose clamps inside the engine bay gave me a struggle, or than that not bad.
  17. #57 Re: Heater Core Replacement
    Jul 2016
    Michigan
    Quote Originally Posted by spazzz View Post
    Thanks. I appreciate the help.
    Sent from my XT1254 using Tapatalk
  1. Heater Core Replacement 97-03
    By Jakescoots in forum How To Write-Ups/Tech Tips
    Last Post: 01-20-2022, 05:21 PM
  2. heater core
    By gtpinsc in forum General Tech Discussion
    Last Post: 04-01-2011, 12:29 PM
  3. heater core
    By PONTIACGTP05 in forum Introductions/Noob Questions
    Last Post: 04-08-2010, 10:24 PM
  4. Ze heater core
    By Spazztic2003 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-08-2009, 03:23 PM
  5. Heater core replacement....
    By m0ng00se in forum General Tech Discussion
    Last Post: 11-19-2008, 10:10 PM
