im just gonna say, get the CEL fixed, then worry about the next issue, the two are probably related.
Crossing my fingers that I don't have to work this weekend. That will allow me to be able to get the new downpipe installed and fix the P0420.
We'll see what I find from there. I'm just surprised no one else has ever experienced this.
i would think the 2 are not related at all, air bag light means air bag problem, cel is a engine problem, not the same cant even be read by the same scanner.
you may have a loose wire, or bad part somewhere related to the air bag.
try looking under the d/s seat, for the yellow wire, that maybe acting up on ya.
and the air bag module is under the front pass seat, under the rug, they get wet and corrode, remove it sand the the corrosion off and screw it back in.
just what coming off the top of my head.
But the airbag light ONLY comes on under highway speeds. It wont come on any other time.
Just today, I went to pass someone on a two lane, took it up to 70 to make the finish the pass, the airbag light came on about 65, and shut off as soon as I got back below 60.
When it does come on on the bypass, its only on for 5-10 seconds at a time.
There is no vibration. I have tried to make it come on by drivng the car hard, punching the throttle, etc. It only comes on under normal cruising at speeds around 55+, and it only stays on for 10 seconds at a time.
