Thread: Rear Fascia question..
Results 1 to 20 of 29
  1. #1 Rear Fascia question..
    Donating Users joshuaandrew92's Avatar
    Jul 2010
    Bluffton, IN
    Will the 06 SE rear fascia just bolt/screw right in to a 04 rear bumper or do i have to get the whole 06 bumper????
  2. #2 Re: Rear Fascia question..
    Omaha, NE
    It should pop right in.
  3. #3 Re: Rear Fascia question..
    Jul 2010
    Bluffton, IN
    It should just like pop in with clips or...? From looking at my factory fascia it looks like there may be like 4 screws or something in it
  4. #4 Re: Rear Fascia question..
    GT Level Member Jakescoots's Avatar
    Spring Lake, Mi
    I think it's those stupid push pin things
    Does removing the spare count as weight reduction?
    Badges on a car are just advertisements....Everyone already knows what it is. And if they dont, its a mystery. People like mysteries.
  5. #5 Re: Rear Fascia question..
    SE Level Member GT40's Avatar
    Hinton, Iowa
    just fixed my yesterday its 2 of those gay push tabs that go into eachother an 2 that go into the styrofoam bumper then 24 snap tabs that just fit in the holes
  6. #6 Re: Rear Fascia question..
    Omaha, NE
    Quote Originally Posted by GT40 View Post
    04+ are a little different. I think we only have 12 wider snap tabs.
  7. #7 Re: Rear Fascia question..
    Omaha, NE
    There's flat tabs that go in first, then 4? body pins, and last is 2 plastic screws on the tabs in the bumper foam.
  8. #8 Re: Rear Fascia question..
    Jul 2010
    Bluffton, IN
    Sounds like it may be a *****... but it looks so good
  9. #9 Re: Rear Fascia question..
    Omaha, NE
    Its not diffiuclt at all. Undo the pins with pliars, unscrew the screws in the foam and pull. It should be 5-10 minutes to swap them out.
  10. #10 Re: Rear Fascia question..
    It's simple...there's 4 push pins you have to remove and snaps into place.
    04 Comp G.
  11. #11 Re: Rear Fascia question..
    Chilliwack BC
    on my car (2008) i had to cut 4 tabs off since they wouldn't line up. and used a crapload of 2 sided tape the first time around.
    now i've replaced tape with seam sealer. that ***** is never coming off you'll just have to find out when you get it but was definately an easy install
  12. #12 Re: Rear Fascia question..
    MO
    ^Well you're the only one. I also have had mine off my 06, very easy to do, just don't be afraid to pull hard on it.
    <brandonl2000> LMAO D!!
  13. #13 Re: Rear Fascia question..
    London Ont, Canada
    i think im warming up to the SE rear.. damn you Couch!
  14. #14 Re: Rear Fascia question..
    SE Level Member GP_Kid18's Avatar
    May 2008
    Palatine,Illinois
    Where can you buy this? I was looking to do this mod as well
  15. #15 Re: Rear Fascia question..
    Kansas
    If you don't know where to get it, then you can't afford it.
  16. #16 Re: Rear Fascia question..
    London Ont, Canada
    Quote Originally Posted by NegativeOne13 View Post
    even if you DO know where to get it, you still cant afford it!
  17. #17 Re: Rear Fascia question..
    GTP Level Member Javi's Avatar
    OKC, Oklahoma
    LOL!
  18. #18 Re: Rear Fascia question..
    Chilliwack BC
    www.gmpartsdirect.com or your local GM dealer. and yes i know i'm a party pooper.
    read up on drunkie's thread on visual mods for 04+
    http://www.grandprixforums.net/04-ap...ods-40397.html
  19. #19 Re: Rear Fascia question..
    Jul 2010
    Bluffton, IN
    Thanks guys for the advice... What about swapping out the exhaust tips? Is that a MUST? or will my factory tips work
    edit - couch, the red on your car makes me happy in pants
  20. #20 Re: Rear Fascia question..
    Donating Users Dboy23's Avatar
    Aug 2008
    Michigan
    Quote Originally Posted by joshuaandrew92 View Post
    I had 4" tips on mine, they fit perfectly, not too big not too small.
    Also just so you know the stock SE's there's a tab on either side that is supposed to slide into the bumper but obviously the stock 04'+ don't have them so you gotta cut the tabs off, I think there was one or two screws in the wheel well and the tabs of course.
    *sig is too tall*
  1. Sillver rear fascia on 2004
    By nyydmb12 in forum Visual/Body Modifications
    Last Post: 08-24-2010, 04:58 PM
  2. Rear fascia Removal '07 GT
    By ovaleasy in forum Visual/Body Modifications
    Last Post: 02-22-2010, 10:28 PM
  3. SE rear fascia
    By GP_Kid18 in forum Audio, Security & Visual Electronics
    Last Post: 01-04-2009, 01:28 PM
