All that has been said is great, but I want to you a question. Do you have anything directly wired to the battery negative post? I did once, and it gave me a similar warning after a bit of driving. What messed me up is the warning didn’t activate immediately. Anyway if you have an amp or HIDs hooked up to the battery you need to run the negative wire through the amp meter located beside the battery.
