Thread: Original Tires/Spark Plugs
Results 1 to 20 of 31
  1. #1 Re: Original Tires/Spark Plugs
    GT Level Member starscream5000's Avatar
    Kentucky
    Dielectric grease actually will help with the electrical contact and will prevent corrosion, and will also prevent the boot from fusing to the plug like your current ones are.
    I just use regular pliers to grip the boot of the plug, is it needed? No, but it's easier than squeezing as hard as you can and hoping your hand doesn't slip off and you bang up your knuckles. The pliers will give you more leverage as well and you will need it to get those plug boots off for the first time.
    2005 GTP - AL 605's gapped at .055", SD headers, WAI with 9" cone air filter, 180 degree t-stat, green coolant, otherwise stock.
  2. #2 Re: Original Tires/Spark Plugs
    Illinois
    Ok, Thanks.
  1. spark plugs
    By gtpdriver in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-04-2011, 01:22 PM
  2. spark plugs...
    By gtpsleeper in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-23-2010, 09:40 PM
  3. spark plugs
    By silverstreak in forum General Tech Discussion
    Last Post: 08-01-2009, 06:09 PM
  4. Spark plugs
    By Chleby in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-16-2009, 10:43 PM
  5. What spark plugs?
    By Dwhip in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-25-2009, 08:21 PM
