Thread: not enough boost
Results 1 to 13 of 13
  1. #1 not enough boost
    boston
    I have an 07 gt just had to replace the water pump and belts along with tires and rotors. Ever since then (as I can remember) Im not getting even half of the boost out of it judging by the in dash boost gauge and its way slower now. I dont know what could have caused that. supercharger oil hasnt been changed since about 65k (I have 87 on it now), air filter seems clean. Anyone who could help I would appreciate it.
  2. #2 Re: not enough boost
    Houston
    If your boosted you dont have a GT unless you did a top swap. But it sounds like a vacuum leak. I'd go through your lines and inspect them. Especially under the S/C nose drive. Here is a diagram. Pay no attention to the circle..it was for a boost gauge thread.
  3. #3 Re: not enough boost
    07 GT = supercharged brah
    05 was the last year for the GTP name, GT were givin the SC motor.
    And yea, check your vac lines.
  4. #4 Re: not enough boost
    Houston
    Good call...didnt know that. Maybe thats why they went bankrupt.
  5. #5 Re: not enough boost
    Waukesha, WI
    lol they went bankrupt for alot of reasons
    RayRay
    92 Turbo miata
    71 bagged lemans wagon
    02 lexus is300
  6. #6 Re: not enough boost
    Houston
    This had nothing to do with it.
  7. #7 Re: not enough boost
    Photobucket killed GM?
  8. #8 Re: not enough boost
    GT Level Member RotyP's Avatar
    Tn
    I learn something new everyday!
    2007 Grand Prix GT - 20% Tint, Red Inlays
  9. #9 Re: not enough boost
    Houston
    Hmmm...I guess the picture of the Aztec was sooo ugly, photobucket said 'no'
  10. #10 Re: not enough boost
    Quincy, Mass
    check your plugs and wires, hows other routine maintenance looking? these types of things can cause power loss. less boost doesnt always mean less power with a supercharged engine.
    No more GP 04 Impala SS Indy:
  11. #11 Re: not enough boost
    SE Level Member collegewrench's Avatar
    iowa
    is it possible you routed the s/c belt wrong? it may look good, but i did it before to where it wasn't tight enough and slipped when engine reved. dnt ask how i managed it, but it can be done. lol
  12. #12 Re: not enough boost
    boston
    yeah I'll have to check the belt. ill prob take it to the dealer for the other stuff. my maintenance could be behind I know i'm prob overdue for plugs and i'm pretty sure i need to change the supercharger oil. thanks guys
  13. #13 Re: not enough boost
    MA
    id recheck your belt. and check for a vaccum leak chances are one, or both, of these is/are your problem.
    SMGPFC Member #9
  1. No boost?
    By 90oddz in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-16-2011, 08:45 PM
  2. Why is my boost gauge only reading vacuum and no boost?
    By gtp02 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-21-2010, 02:26 PM
  3. 20 PSI of boost!!!!????
    By kirkkarem1212 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-19-2010, 05:46 PM
  4. dic boost gauge only shows half boost
    By SilvaMan61 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-10-2010, 07:40 PM
