been doing a little shopping. Im looking at getting a TB spacer and heatshield. Do the ones on ZZP work for an 04 GTP? anyone used them?
Both are not a good idea at all.
Unless you're going to spray meth or N2O.
i want to get a ported TB but i really dont want to have to reprogram the pcm. what is the water pump mods youve done matt?
X2, Worthless mods
my water pump bearing is starting to fail.
it screams on a cold idle till it warms up a little.
dumb question whats an underdrive pulley? how does it add HP and give better fuel economy?
it will use less energy to turn the water pump.
bad idea.
namely because cooling is good.
thats what i figured but it just kind of confuses me i understand cutting out the ac but water pump?
if our cars were lighter then i'd suggest power steering delete as well.
feels like theres not much else i can do to my car outside of engine internals or spending $1000+
basically going fast costs money.
do a cam or some rockers, youll see huge gains from the cam depending on the size. Rockers not so much, its just something to do.
im jsut gona do rockers when i get the money. Getting my new transmission in it today f-na right!!!!![]()
that^ OR... save up just a tad bit more money and cam! youll love yourself for it. Also with a cam its a gateway mod you can drop to crazy small pulleys (aslong as your tuned) and run bigger TB's its just a better and overall idea. Plus there is nothing better then hearing that sweet loping sound at idle!![]()
i would but i dont have the cash and i would have to get the pcm reprogrammed too much $$$$$. Unfortunatly its still a DD so i dont want to cam it
well okay, but since your going roller rockers, i recomend 1.9 with #105 springs and comp cam push rods for the most gains even though theyll be minor you should still feel the extra power towards the top of your shifts.
thats what i was looking at
