Now all that being said, its time to show you all how to make clear corner sidemarkers.
-Go to Lowe's or Homo Depot and pick up some clear plastic styrene for florescent lighting. I got a 2x2 piece that was damaged for $1
-Take the headlights off the car and preheat your oven to 215*-225*.
-Get a hand towel from your bathroom and get it damp and lay it on the bottom of a cookie sheet, Lay the headlight on the cookie sheet (Remove the rubber gasket and all the bulbs)
-Put the cookie sheet and headlight in the oven for between 5-10 minutes
-Keep an eye on the headlight
-Use a Screwdriver to pry on the tabs on the top and bottom of the light, and then at the larger end where the lip is on the lens, pull on the two halves and they should seperate.
