Thread: D.I.C. problems
Results 1 to 10 of 10
  1. #1 D.I.C. problems
    Destroys cars izup69's Avatar
    Iowa
    Ok I have got other problems with my car lol. After I installed my new headunit my D.I.C. started acting up. If I set the date on it it resets itself and if I calibrate the compass it also resets itself. Was wondering if the compass was in the stereo or if the memory was in the stereo and if it is just the memory what would be a way to fix it. Everything else works on the D.I.C. fine no reseting of it
    06 base open cone,2.5 inch dp into high-flow cat,window tint,drilled rotors.
    97 GTP ubend delete,drilled and slotted rotors,de-badged,open cone,6k HID,All aftermarket speakers
  2. #2 Re: D.I.C. problems
    Nov 2008
    ohio
    your compass should still work but the date will not, that's why there was the wires from the DIC to the stock head unit...
    04 Grand Prix GTP (Wizaired, 3 inch downpipe)
  3. #3 Re: D.I.C. problems
    Iowa
    yeh got the compass to work is there anyway to fix the date problem some sort of connection I can hook up ??
  4. #4 Re: D.I.C. problems
    Nov 2008
    ohio
    ya only if you n1gger rig it where you put the factory radio in the trunk to retain the factory chime and date, but its not worth it, just leave the dic on mpg so you know how bad ur getting.
  5. #5 Re: D.I.C. problems
    Iowa
    nah I get good gas millage about 25-28 depends. When I drive it to work I get about 30mpg. When my wife takes it to her moms she gets about 23 so it averages about 25-28.
  6. #6 Re: D.I.C. problems
    Nov 2008
    ohio
    is yours supercharged? I saw you had 104's and a 2.5 in downpipe???
    that dont make sense
  7. #7 Re: D.I.C. problems
    Iowa
    nah I'm n/a my dp had a hole in it so I replaced it and upgraded while I was at it. Plus I wanted a hotter plug for the car so I got 104's. Just took a trip to chi-town yesterday and calculated my mpg my D.I.C. said I was getting 26.1 but by my calculations I got 31+
  8. #8 Re: D.I.C. problems
    Nov 2008
    ohio
    ya mine always reads low too. a autolite 104 is a colder plug though!!!
  9. #9 Re: D.I.C. problems
    El Paso, TX
    I've asked a millioin times (ok maybe twice) but how do I move the stock radio to the trunk? (don't wanna thread jack, sorry)
  10. #10 Re: D.I.C. problems
    Iowa
    basically u just take the black plug that u don't use on your new headunit and run those to the back of ur car with the 12v power plug em in and go lol
  1. Problems
    By BThomp in forum Introductions/Noob Questions
    Last Post: 08-22-2010, 05:54 AM
  2. A/C problems
    By 99prixgt in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-03-2009, 11:04 PM
  3. 07 gxp with nav mp3 problems
    By pjs29 in forum General Tech Discussion
    Last Post: 08-22-2009, 01:11 PM
  4. 3 last problems
    By indyal in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-22-2009, 06:14 AM
  5. problems problems problems!
    By NomeCrusher in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-14-2009, 03:26 PM
