Ya, unfortunately I have. If you remove the piece of plastic inside of the cabin near the door/floor area there is a small cutout that is on the inside the A pillar; reach inside and you car pull out the bottom of the sunroof drain tubing.
It's wild it like it just lays there and the water drains somewhere> I can't fit my whole hand inside the hole to feel were it's supposed to drain. But it fills up and the only place for the wter to go is inside of the passenger compartment.
I pulled the same panel off of the driver side, it's by the e-brake and the same thing but this one drains great. Drains kinda in-between where the panels come together underneath the car.
Thanks for the heads up about the water deflector though.
