There is a TSB for the aluminum subframe to creak or pop. The solution is to inject some compound into the frame welds to stop it from happening.
I would also look into simply tightening your cradle bolts. That what was causing my Impala to do it... loose bolts. A little blue loctite and I never had the issue again.
