Thread: Body panel question 07 sedan
Results 1 to 6 of 6
  1. #1 Body panel question 07 sedan
    GTX Level Member WhiteDevil's Avatar
    Aug 2008
    60118 NE Illinois
    I need to know what the part is called.
    It would normally be a seperate piece called an "Air Dam", however from the diagrams it appears the 04+ GP has them integrated into the extension piece..
    I need to order a new one and would like to order the right part, Thank in advance for your time.
    What is this part truly called today and is there a difference in models?
    It appears to be attached to #7
  2. #2 Re: Body panel question 07 sedan
    Donating Users Dboy23's Avatar
    Aug 2008
    Michigan
    It's called an Air Dam, that's what the guy at GM will call it, personally I'd go for the SE (Special Edition they only had for 2006-2007) you can see it in my sig on my car, it's a little bigger and is meant to be painted to match the car. It'll cost you about $280 for this one and maybe half of that for the original front Air Dam. Other than the Special Edition (SE/Spring Special) Air Dam they're all the same from 04+.
    *sig is too tall*
  3. #3 Re: Body panel question 07 sedan
    Nov 2009
    Pittsburgh
    In case anyone else come across this old question, it's called the lower air deflector. Just bought one & it lists for about $100.00
  4. #4 Re: Body panel question 07 sedan
    MA
    Quote Originally Posted by Rebuilder View Post
    100??? Where did you get it for that??
  5. #5 Re: Body panel question 07 sedan
    Nov 2009
    Pittsburgh
    GM dealer. Perhaps we are not talking the same part? What I am refering to attaches to the bottom of the rad supt, bumper reinf bar and the lower bumper cover. It is black plastic and has a spoiler or air dam/deflector molded in. It's the thing that sticks down & always gets drug against curb stops. This is the same part from 04-08 on the base models and GTs.
  6. #6 Re: Body panel question 07 sedan
    Aug 2008
    Michigan
    What your thinking of is number 11, he's referring to the front Air Dam which is number 7.
    *sig is too tall*
  1. Question to those who have or will have their front int. door panel off
    By mntnbiker in forum Audio, Security & Visual Electronics
    Last Post: 06-30-2009, 09:13 AM
  2. rocker panel replacement??help??
    By brian91z34 in forum General Tech Discussion
    Last Post: 02-23-2009, 09:23 PM
  3. Door panel
    By chrisp847 in forum Audio, Security & Visual Electronics
    Last Post: 02-18-2009, 02:26 PM
  4. question about part of the stock body
    By The_Avenger in forum Visual/Body Modifications
    Last Post: 03-09-2008, 10:48 AM
