Thread: Brake pedal return issue... unsure if booster or something else
Results 1 to 9 of 9
  1. #1 Re: Brake pedal return issue... unsure if booster or something else
    how do the brakes feel over all? the pedal mushy and push to the floor or normal firm feeling? or maybe hard as a rock?
    if its mush the master is going bad, or it needs to be bleed. rock hard means the boosters not working right. engine off if you pump the brakes the pedal should get harder and harder with each push as it uses up the vacuum in the booster. they can rust and leak out the vacuum on ya running and cause a hard pedal.
  2. #2 Re: Brake pedal return issue... unsure if booster or something else
    Feb 2020
    NE
    They feel fine overall.
    No binding, no spongyness, firm normal GM brake pedal except for not coming back all the way.
    Not feeling any drag from them either
    Sent from my SM-G975U using Tapatalk
  1. Brake booster
    By 94grandprix in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-23-2021, 06:29 PM
  2. Brake Pedal Vibration Issue
    By Singlealt in forum General Grand Prix Discussion
    Last Post: 02-25-2018, 11:17 PM
  3. Brake Booster on 2001 GP 3.8 GT
    By scha0786 in forum General Tech Discussion
    Last Post: 05-16-2016, 07:49 AM
  4. Brake Booster
    By grandamle91 in forum Brakes/Suspension/Chassis
    Last Post: 02-09-2014, 12:15 PM
  5. Bad brake booster?
    By Pure2sin in forum General Tech Discussion
    Last Post: 01-27-2012, 11:58 PM
