Thread: Transmission Rebuild: CAT Fluid/Dex VI or Amsoil?
Results 1 to 7 of 7
  1. #1 Transmission Rebuild: CAT Fluid/Dex VI or Amsoil?
    Jan 2018
    US
    I'm hearing and reading a lot of things and wanted to see what you guys think as well. I'm rebuilding my tranny and wonder what will be recommended for my 04 GTP. I know Dex VI is the route but I was curious about
    The Dex VI mixed with CAT fluid? And what's the ratio?
    And or Amsoil?
    Any thoughts...
    Sent from my SM-N950U using Tapatalk
  2. #2 Re: Transmission Rebuild: CAT Fluid/Dex VI or Amsoil?
    If this was 2004 it would still be DEX 3 on the dipstick as I though it was 2005-2006 that switched to the newest DEX 6 as the older fluid was phased out (superseded).
    For as simple as these transmissions are and for what the fluid has to do I'd toss that cheap dex 3 right back in it without a single care in the world.
    Putting in DEX 6 or using amsoils or cat fluid isn't going to do some voodoo magic and make it run better.
  3. #3 Re: Transmission Rebuild: CAT Fluid/Dex VI or Amsoil?
    Mar 2014
    Tucson
    Agreed. For a daily driver, the type of fluid is less important the the sustained operating temperature. Take the money you save and put it towards a cooler.
  4. #4 Re: Transmission Rebuild: CAT Fluid/Dex VI or Amsoil?
    Jan 2018
    US
    Quote Originally Posted by BrandonHall10 View Post
    Yea, I have a TruCool Max ready to be installed and if I dont have the balls to modify it I'll still install a Trans Cooler I got from a Ford Explorer.. But this is what I've done so far..
  5. #5 Re: Transmission Rebuild: CAT Fluid/Dex VI or Amsoil?
    Jan 2018
    US
    Haha true for the voodoo part. I've upgraded input shaft/chains and installed a few things in the Valve body from Sonnax and also added 3rd clutch piston from Sonnax. Trying to get what's best for what I can afford now. This tranny cant fail me anymore haha. If it does, it'll be my mistake haha
  6. #6 Re: Transmission Rebuild: CAT Fluid/Dex VI or Amsoil?
    I break stuff selliott's Avatar
    Kansas City
    I run amsoil in all my vehicles, trans, oil etc.
  7. #7 Re: Transmission Rebuild: CAT Fluid/Dex VI or Amsoil?
    Search on my name and the cat fluid. I forget how much Dave at TEP said to add. It might have been half or so.. but don't do it w/o confirming it.
    The reason for doing the cat fluid was because it sticks to components better and keeps them lubed better under stress.
  1. Transmission rebuild
    By Trevor in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-24-2017, 10:06 PM
  2. Ran car with no transmission fluid...
    By DirkJr in forum Introductions/Noob Questions
    Last Post: 05-28-2014, 10:30 AM
  3. Transmission fluid
    By ChevMan92 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-23-2010, 07:54 PM
  4. Will I need a rebuild or new transmission?
    By grandprix85 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 12-02-2009, 01:29 PM
