Thread: Choosing a Flexplate
Results 1 to 10 of 10
  1. #1 Choosing a Flexplate
    Jan 2018
    US
    Rebuilding my 4T65E-HD and got a new torque converter.. Looked at my old OE flexplate and it's a rust mess...
    My question is, what flexplate should I buy? OE, ZZP HD or Meziere.
    Will love to hear any input or info. Thanks
    Sent from my SM-N950U using Tapatalk
  2. #2 Re: Choosing a Flexplate
    If your power level doesn't require anything better than stock.. I'd go stock.
  3. Likes showtastiik liked this post
  4. #3 Re: Choosing a Flexplate
    Kemmerer, Wyoming
    I went with the one from zzp because it had the dual bolt pattern and that's what I needed.
  5. #4 Re: Choosing a Flexplate
    Jan 2018
    US
    Need a tune after thus for sure. Either canned or help from others HP Tuners but With what I have in the top end supporting mods for 3.4 Pulley with no KR, CNC Ported heads, on my 04 GTP, not sure what type of power I'll be working with. I just decided to upgrade my stock chains to the GXP Gimini Chain set. Torque Converter is new stock. So thinking I might be good with just stock Flexplate.
  6. #5 Re: Choosing a Flexplate
    Jan 2018
    US
    Quote Originally Posted by SgtMarshal View Post
    I guess it's just depends on how far I'm trying to take my car as for HP goes right?
  7. #6 Re: Choosing a Flexplate
    Kemmerer, Wyoming
    a higher stall will get you into your powerband faster regardless of your hp goals
  8. #7 Re: Choosing a Flexplate
    Jan 2018
    US
    TC is what you meaning by stall right? Noob over here ha
  9. #8 Re: Choosing a Flexplate
    Kemmerer, Wyoming
    TC aka torque converter, and yes
  10. Thanks showtastiik thanked for this post
  11. #9 Re: Choosing a Flexplate
    I was stock flexplate in my Bonneville with :
    Stage 3 heads
    Intense S1X cam
    Harland 1.8 roller rockers
    HD pushrods (right length for the setup)
    I forget which springs
    SLP Headers
    PRJ fuel rails
    PRJ plug wires
    WB store super thick intercooler with VW radiator and meziere 20gpm pump, two added overflow tanks.
    Upgraded fuel pump
    Gen V M90 with 2.9 pulley
    Northstar TB
    4" intake tubing
    LQ4 maf
    Meziere electric water pump
    Modified engine mounts (subframe flexed)
    Oil pressure kit (brings it up about 10psi)
    Aluminum oil pan
    3" exhaust back to bend by fuel tank.. then 2.5"
    Built trans with 3.29's and HD precision torque converter (did the converter based on the added weight of the car over a w body)
    Quite a few items.... and stock flex. Never broke one in this car.
  12. Thanks showtastiik thanked for this post
  13. #10 Re: Choosing a Flexplate
    Jan 2018
    US
    Stage 3 heads
    Intense S1X cam
    SLP Headers
    PRJ fuel rails
    PRJ plug wires
    Upgraded fuel pump
    Northstar TB
    4" intake tubing
    LQ4 maf
    Aluminum oil pan
    Sweet!! Enough said for me ha
  1. need help choosing a cam
    By lance4682 in forum General Tech Discussion
    Last Post: 05-07-2014, 07:13 PM
  2. Need Help Choosing The Right Tires!!
    By Foxy333 in forum Tires & Wheels
    Last Post: 10-16-2013, 08:49 PM
  3. Choosing the right cam
    By Steven Monteith in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-19-2012, 11:51 PM
  4. Choosing the right (s)way
    By Axby523 in forum Brakes/Suspension/Chassis
    Last Post: 05-30-2012, 05:04 PM
  5. choosing a new deck???
    By silverbullet10 in forum Audio, Security & Visual Electronics
    Last Post: 02-15-2011, 12:27 AM
