Thread: No start or crank plz help
Results 1 to 5 of 5
  1. #1 No start or crank plz help
    Sep 2017
    Arizona
    Ok so i have a 2005 gtp and i can not get it to start or even crank when i turn the key everu thing else works fine the only way i can get it to start is the take a wire and jump the starter but once i do that and the car is running ot runs fine but it wont shift it to gear ive tried doing the relearn thing but still nothing im going crazy sum one plz help
    Sent from my LGMP450 using Tapatalk
  2. #2 Re: No start or crank plz help
    on the starter is a small purple wire, small stud, have someone turn the key to crank while you test that wire for power. thats the signal wire that tells the starter to crank.
  3. #3 Re: No start or crank plz help
    Mar 2017
    Internet
    04+ get the signal from the pcm. PCM looks for certain inputs. Let's jump back to the basics. Move the shifter into N, try to start it. Move it back to P, try to start it. The safety of N and P are often overlooked and sometimes the shifter isn't fully engaged. While you are shifting it around, .. Look at the information center to see what gear you are in. If you don't see N/P or other movement, then know you have a bad switch or wire.
  4. #4 Re: No start or crank plz help
    Sep 2017
    Arizona
    Quote Originally Posted by BillBooost37 View Post
    What a bad neutral safety switch or what wire?
  5. #5 Re: No start or crank plz help
    Sep 2017
    Arizona
    I dont think it shows on what gear your in on the dash
  1. Crank no start!
    By RobGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-30-2014, 09:09 PM
  2. Crank but no start.. Help!
    By GTP89 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-09-2013, 11:31 PM
  3. Crank but not start
    By Coldwaves in forum General Tech Discussion
    Last Post: 05-20-2013, 05:21 AM
  4. Crank, but no start
    By JoshMcMadMac in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-24-2010, 11:28 PM
  5. No Crank - No Start!!
    By coolken84 in forum General Tech Discussion
    Last Post: 03-05-2009, 10:15 AM
