Quote Originally Posted by BillBooost37 View Post
04+ get the signal from the pcm. PCM looks for certain inputs. Let's jump back to the basics. Move the shifter into N, try to start it. Move it back to P, try to start it. The safety of N and P are often overlooked and sometimes the shifter isn't fully engaged. While you are shifting it around, .. Look at the information center to see what gear you are in. If you don't see N/P or other movement, then know you have a bad switch or wire.
What a bad neutral safety switch or what wire?
Sent from my LGMP450 using Tapatalk
