Thread: Anyone with an 05+ interested in a smaller alternator pulley?
Results 1 to 18 of 18
  1. #1 Anyone with an 05+ interested in a smaller alternator pulley?
    GXP Level Member
    Mar 2015
    Tomball
    So I have set my idle a little lower than normal to keep the car from pulling in gear in traffic and have noticed that the alternator cannot keep up at this low of an RPM the voltage would start out at 14.6 and slowly fall into the 12.1 range then kick back up to about 13V for a second then back down and wouldn't increase unless the engine speed increased, the fans would also speed up and slow down with this as well. I ended up buying a new smaller alternator pulley that measures 1.9" across the top of the ribs (Stock is 2.43"). This is nice and all, but the pulleys all have the offset about 7/16" away from the pulley and would pull the belt out of alignment. Not only that but the shaft is is so short that the new pulley doesn't even have any exposed threads. I ended up turning it on a lathe and got it down to where it fit perfectly and now even with the AC full blast and the lights on the voltage is able to hold and my fan no longer rises and falls with the idle. I may buy a few extra's and machine them if there is any interest or need.
    Jeff
  2. #2 Re: Anyone with an 05+ interested in a smaller alternator pulley?
    GTP Level Member LeadfootCJ7's Avatar
    Oct 2012
    Houston, TX
    Would this also work on the GXP?
    2007 Grand Prix GXP;2002 Camaro Z28 - tune, CAI, and exhaust
    2006 GMC 2500HD - ATS high flow manifolds and uppipes, turbo back exhaust, blocked EGR, Denali headlights, Reflexxion Cown Hood
    1994 Olds Cutlass Supreme 2 door
  3. #3 Re: Anyone with an 05+ interested in a smaller alternator pulley?
    GXP Level Member
    Mar 2015
    Tomball
    Not sure. I did one for my 05'GTP 05-08 are the same but 04 uses a clutch and I haven't looked into it. Take a picture and post it and I'll see it I can tell.
  4. #4 Re: Anyone with an 05+ interested in a smaller alternator pulley?
    May 2012
    lebanon ohio
    I would be interested. How much would it cost?
  5. #5 Re: Anyone with an 05+ interested in a smaller alternator pulley?
    GXP Level Member
    Mar 2015
    Tomball
    Depends on how many I were to do. Single would be about $40 plus shipping. Doesn't look like there is much interest so unless I can get them at a better price or get them cheaper buying multiples and getting them cheaper that's about what it would be.
    Jeff
  6. #6 Re: Anyone with an 05+ interested in a smaller alternator pulley?
    GXP Level Member
    Mar 2015
    Tomball
    Quote Originally Posted by LeadfootCJ7 View Post
    Hell you are in Houston, let me look at it and I can tell.
    Jeff
  7. #7 Re: Anyone with an 05+ interested in a smaller alternator pulley?
    Oct 2012
    Houston, TX
    Come to Coffee and Cars next Saturday
  8. #8 Re: Anyone with an 05+ interested in a smaller alternator pulley?
    I break things. WarStryker13's Avatar
    Oct 2014
    Frederick, MD
    the 04 alt pulley is smaller than 05-08, ~2.1'' IIRC. IDK if it has anything to do with the clutch inside, I don't understand why it has one, or why it's the only year that has one lol
    04 GP GT2: Handling upgrades, go-slow parts, and an attitude. Totaled.
    87 Dodge Ram 50:​ Junkyard rescue, resurrection in progress.
  9. #9 Re: Anyone with an 05+ interested in a smaller alternator pulley?
    May 2012
    lebanon ohio
    If you do decide to make some let me know. Thanks
  10. #10 Re: Anyone with an 05+ interested in a smaller alternator pulley?
    GXP Level Member
    Mar 2015
    Tomball
    Quote Originally Posted by WarStryker13 View Post
    I don't know why they think they are a good idea or were a good idea. Someone dropped the ball in thinking about how the system works anyway. The only time that clutch will come into play is if when the engine is shut off and there is no electromagnetic drag from any risidual flux in the rotor acting on the field. That is the only time it really freewheel. I have heard a couple of people trying to diagnose a bad bearing sound when they shut off the engine and the clutch is what it turned out to be.
  11. #11 Re: Anyone with an 05+ interested in a smaller alternator pulley?
    Oct 2014
    Frederick, MD
    IDK, but mine is special, and I think I'm gonna pull the case off and repaint it, throw it back on. lol
    But I can take the pulley off and take detailed pics, see if they are really that different than the 05+ and whether you can rename this thread.
  12. #12 Re: Anyone with an 05+ interested in a smaller alternator pulley?
    Or you can just buy one already powdercoated
    04 Comp G.
  13. #13 Re: Anyone with an 05+ interested in a smaller alternator pulley?
    Oct 2014
    Frederick, MD
    Quote Originally Posted by REDCRAPGP View Post
    Or I can spend a fraction of that price, since I'm going to upgrade to the CS144 eventually. Lol
  14. #14 Re: Anyone with an 05+ interested in a smaller alternator pulley?
    GXP Level Member
    Mar 2015
    Tomball
    Not sure you can do that on the 05+ anyway. I'm iffy on the 04+. Besides I only did it because of my commute and 125 amps is more than plenty for a dual battery car with up to 2Kw stereo.
    Jeff
  15. #15 Re: Anyone with an 05+ interested in a smaller alternator pulley?
    Oct 2014
    Frederick, MD
    Mine will be that plus an insane amount of lighting... It's dark here for 9 months out of the year. Lol
  16. #16 Re: Anyone with an 05+ interested in a smaller alternator pulley?
    GXP Level Member
    Mar 2015
    Tomball
    Is that this Saturday? What part of town?
  17. #17 Re: Anyone with an 05+ interested in a smaller alternator pulley?
    Omaha, NE
    Can I run this in parallel with my stock alternator pulley?
  18. #18 Re: Anyone with an 05+ interested in a smaller alternator pulley?
    GXP Level Member
    Mar 2015
    Tomball
    Only if you know how....
  1. Old Thread
    By SpeedGrid in forum General Grand Prix Discussion
    Last Post: 08-05-2014, 07:10 AM
  2. Smaller Pulley on '00 GTP
    By usdmaf in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-15-2014, 08:05 AM
  3. Do I really need a smaller belt with my smaller pulley?
    By 97AutoXVette in forum General Tech Discussion
    Last Post: 04-04-2014, 12:36 PM
  4. smaller pulley
    By kunkelz28 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-22-2010, 02:01 PM
  5. new belt w/ smaller pulley?
    By PonchoDvr4Lfe in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-25-2008, 05:54 AM
