Thread: Anti-theft or other issue?
Results 1 to 7 of 7
  1. #1 Anti-theft or other issue?
    Feb 2016
    Central New Jersey (Mercer County)
    Just got home and went upstairs, forgot something at the store and tried to start up my car (04 GTP). Didn't do a thing. Electronics seem to work fine. Won't crank or anything. There's also a fast whir behind the radio/clock cluster that lasts less than a second when I try to start the car. Is this a theft deterrent or something else? I literally was driving 20 min ago.
  2. #2 Re: Anti-theft or other issue?
    dead starter maybe, you hear a click in the dash when the key is turned.
    try the old hammer to the starter, few shots to the body and if it cranks you know its the starter.
  3. #3 Re: Anti-theft or other issue?
    Feb 2016
    Alright thanks I'll get on that now and let you know if anything else turns up.
  4. #4 Re: Anti-theft or other issue?
    Feb 2016
    Alright so I did that and it still didn't start. Probably is the starter. Does it usually just go out like that without warning
  5. #5 Re: Anti-theft or other issue?
    yeah, they can just quit life. if it seems like it had not been turning over as fast in the last few months it could be a sign.
    you can take it off and bench test it with jumper cables before buying a new one.
    if you do need a new one google your town and alternator and starter re builders. the local re builders tend to charge much less then a parts store, and you got a local warranty with the guy who rebuilt it.
  6. #6 Re: Anti-theft or other issue?
    Feb 2016
    Hmm okay. Thanks for the tips. Would oil soak or something like that be a possibility as to why it's now dead as well or are the components completely sealed off
  7. #7 Re: Anti-theft or other issue?
    Apr 2016
    Maryland
    Did you figure out the problem?
  1. anti theft system needs service
    By mamakeel in forum Introductions/Noob Questions
    Last Post: 10-29-2013, 04:05 PM
  2. HELP!! anti-theft ring around key
    By anarchy in forum Audio, Security & Visual Electronics
    Last Post: 01-23-2013, 08:13 PM
  3. Anti Theft/Staerter Issue
    By AStanchiu in forum General Tech Discussion
    Last Post: 11-20-2012, 08:15 AM
  4. Service Anti Theft System
    By silentkreeper95 in forum Audio, Security & Visual Electronics
    Last Post: 03-27-2012, 08:05 PM
  5. Replacing Anti-theft system
    By mvp2765 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-28-2010, 09:03 PM
