Thread: cant fill up tank
Results 1 to 2 of 2
  1. #1 cant fill up tank
    Nov 2015
    ohio
    ok guys I got a good one for you, I just got out of prison after 2 years, and my 04 grand prix sat without starting all that time. I just got it running and the only thing that was wrong after all that time is I have a PO446 code, and the pump keeps shutting off. I have replaced the purge valve canister by the gas tube under the wheel well. didn't work. also I remember it used to always click on and off. I could hear it. now it doesn't like there is no power to it?
  2. #2 Re: cant fill up tank
    Jan 2016
    Ottawa
    If you haven't found a solution yet, try not inserting the nozzle all the way in when filling up. If that works it's the Venturi effect from the nozzle, some newer gas pumps don't like grand prixs for some reason.
  1. Gas Tank Hard to Fill
    By jeffconnors in forum General Tech Discussion
    Last Post: 11-06-2012, 06:28 PM
  2. Coolant Fill
    By LapeerGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-15-2012, 07:16 AM
  3. how do i fill silencers
    By DOUGLASMELTER in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-24-2011, 06:05 AM
  4. How to fill cylinder with air?
    By TheOtherNick in forum General Tech Discussion
    Last Post: 01-15-2009, 11:55 AM
  5. Metal Gas Tank Flap Broken off and Into Tank
    By indplsin72 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-15-2008, 08:35 PM
